Results 1 to 3 of 3
Thread: VR CLUBSPORT drivetrain noise
    SLR
    SLR is offline
    VR Clubsport
    Aug 2005
    Default VR CLUBSPORT drivetrain noise
    Hi, I get binding and a slight grinding noise in the drive train somewhere especially when reversing. I'm thinking drive shaft centre bearing or rear CV's as IRS or maybe tail shaft uni joints. How do I perform a test on these components to find the culprit? thanks
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    i used to hear a grinding noise and i thought it was my timing chain but it turned out to be the trans...check your trans fluid level and top up. uni joints generally make a whining sound and if they were suspect would clunk alot. as for the cvs on the rear jack it up and grab the shaft and apply little pressure to move it if itmoves then they need replacing.
    vs clubsport
    Mar 2009
    brisbane
    the grease can leak out of the rear cv's on the commos after time and they get dry and make a kinda groany noise at low speed
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
  1. Drivetrain Problems
    By sik_dogg_vn in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-07-2009, 05:54 PM
  2. check drivetrain
    By trentvy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-07-2009, 04:17 PM
  3. Drivetrain noise???
    By stealth616 in forum V8 Development and Modification
    Last Post: 21-06-2009, 04:58 PM
  4. Drivetrain Light
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2009, 10:25 AM
  5. vt clubsport clunking noise
    By gazzabrizz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2006, 03:11 PM
