Results 1 to 24 of 24
Thread: VS ecotec, not starting, after no problems and just filled up car
    HICOMPVN's Avatar
    HICOMPVN is offline Wanting That Lil Bit More
    VN Commodore Executive S1
    Mar 2006
    S.E SUBURBS
    Exclamation VS ecotec, not starting, after no problems and just filled up car
    hey guys, got a vn with a vs ecotec, and i can tell you guys, have not been happier with the eng,
    BUT....... today at lunchtime, i filled the car up with United PULP in bentleigh, was driving fine, then went to harvey norman in moorabbin, parked the car, went inside for 30-50 sec's.
    come out to go to jb-hi fi, get in to my car and go to start it and she won't fire, WTF.....
    the same fuel was running the car b4 i filled it up, and was great that's y i went and filled it up witht the same stuff. today!!
    got spark, theres seems's to be fuel in the line, cos it's pressured up, turns over, but will not fire..... i'm pretty cluey when it comes to engines, but i'm sorry this ones really pissed me oFF!!!! got no idea.
    any help
    thought it might be CAS but i'm not sure!!!!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Not sure if you have a VN or VS???...but if it's a VS check that the immobiliser light is not flashing (under the radio) - it must extinguish otherwise the car will not start. If it stays on it may be the keyhead where it makes contact with the ring around the keyhole.
    Good Luck. Also try a fault code check.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    You may have bad fuel. It may hurt and it's a pain in the rear but try draining the tank and replace it with another brand. I recently experienced a bad lot of fuel from Shell.
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    hey dude, i have a VN comm, with a VS ecotec, under the bonnet. my ride as of monday night!!!
    as you can see by the vid it works!!!!
    YouTube - HICOMPVN'S 1990 VN Commodore Exec Sedan V6 With A VS Ecotec Engine!!!
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    LOL yeah i know, already spoken to the company and they havn't got any compaints today apart from me!!!!!
    Vr Executive 3.8
    Dec 2008
    I doubt very much its cause of the fuel even if it was dodgy I'm pretty sure the car would still run, dodgy as but it would still run.
    Tried pulling codes and checking earths?
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    LOL guys, NO codes apart from 12(system ok) there is no probs witht the wiring, I KNOW, cause it's worked no probs!! not 40 seconds before i parked the car!!!, but yeah that's what i thought it would still run if even dodgy fuel!!!
    and also i don't have a 60lt jerry can lying around!!!
    VS Berlina 3.8
    Dec 2008
    Not to sound silly, but is it in park or neutral? Best to start with the easiest.
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    tried the check park sensor, no not that.
    like seriously i was driving the bloddy thing just be for i parked the car, and she was all good!!! got out locked the door, pressed the alarm, went inside for 40-50 secs looking for a RCA to 6.5mm stereo jack, but they didn't have one, went out to get into the car, unlocked alarm, got in turned key to ign, paused, then went to start and just turns over, no fire!!!! BUT THERE IS SPARK!!!!!
    VS executive
    Jun 2009
    well if it was a problem with the key head you wouldnt be getting and turning over at all so rule that one out.
    had a similar situation when my fuel pump went on my VN would turn over but not fire.... so maybe fuel pump was on its last legs when you parked? ( probably not but thats all i can think of )
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    maybe the alarm hasnt disabled check for power on the pink wire going to the ecu with the key on
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    na not the fuel pump, cos i just got her home, and tried to get her going, still no start, but fuel pressure is there, alarm is all good, not that, Would a faulty CAS cause No pulse at injectors....???? cos that's what seems to be the problem, i'm getting no pulse at the injectors, and they are all good.
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    HEY Guys can anyone tell me if a faulty CAS, would be the result of NO PULSE at all 6 injectors
    or what would cause the injectors to stop pulsing???
    they were re-coed before i reinstalled them into the VS COMM engine...
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah cas would do it but would normally show a code .my guess is no power to ecu or injectors is there 12 volts at the injector plugs
  15. #15
    в∞ѕтεכ √&
    Jul 2008
    NZ
    mind you if its flashing codes the ecu is getting power
  16. #16
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    trippy, havn't checked the voltage,m but will do that tomozz
    unless there are other ideas!!!
  17. #17
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Whenever my car won't start its always the DFI . ... might pay to check that. I think spark signal comes from DFI - not sure on that bit tho
  18. #18
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    what you think it could have just stopped working like that, "Snap of the fingers".
    I did just buy a whole new coil pack and dfi module and bracket, well not new, s/hand, from allcomm when i was putting the engine into the car, and it was all good and also, as prieviously stated i have spark.
    Will be looking at the girl a bit more today,
    Might be CAS or injectors i have put it down to, unless someone's put something in my tank but very highly unlikely.
  19. #19
    в∞ѕтεכ √&
    Jul 2008
    NZ
    takes a lot to stop the spark happening the dfi only needs power earth and the cas hookec up to make spark but the dfi can still be dead and not sending to the ecu or half the cas isnt working and utr will still spark just the ecu wont see the pulses it wants for fueling to begin
  20. #20
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    yeah see now that's my thinking of why i might have a faulty CAS,thing's along those lines.
    also off topic but in my posting, how come my avitar doesn't come up or does it and i just don't see it, i put one one and there's nothins.
  21. #21
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
  22. #22
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Quote Originally Posted by HICOMPVN View Post
    I did just buy a whole new coil pack and dfi module and bracket, well not new, s/hand, ....
    Yes, that has happened to me twice in the last few years , driving along hapily one minute ... rolling to a quiet stop the next. Sometimes it will fire up again when cool just like a CAS so it can be hard to tell which is to blame.
  23. #23
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    well i will be taking the harmonic of tomoz to see in the morning, and change the CAS, but if not that, i'll spose i'll have to look at the dfi module!!! grrrr
    well luckily i have a spare floating around! Of both parts!
  24. #24
    HICOMPVN's Avatar
    Mar 2006
    S.E SUBURBS
    Talking
    hey guys, woooohooooo..........
    just thought i would get on and let you all know.... that my baby is alive again!!!!!
    i must have been bitten by the trusty ol DFI module failure bug.
    that's what it ended up being..
    thanks heaps for everyones help, love your work, see you out on the road!!!!!!
    Hicompvn
    matt
  1. Starting problems
    By Bax in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2009, 12:55 AM
  2. VS and VT ecotec Starting issue
    By yyg998vsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 11:38 PM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. Starting problems
    By Emu in forum General
    Last Post: 23-10-2006, 10:11 AM
  5. vp starting problems
    By driver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2005, 12:11 PM
