Results 1 to 6 of 6
Thread: Vr 6 idles iratically in netral and try's to stall when changing from reverse/drive
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Default Vr 6 idles iratically in netral and try's to stall when changing from reverse/drive
    Like it say vr 3.8ltr, it idles all over the place when it's in netral then I put in gear and it seems to idle pretty good, then you back out the drive and go to put into drive and it try's to stall. Driving round and it feels nice and smooth, any idea's? Thanks
    Last edited by pjdm1980; 09-09-2009 at 05:39 PM. Reason: Just in case you didn't know it's a auto
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Remove the throttle body and give it a thorough clean with some carby cleaner. Also remove the IAC valve for a clean and blast the port it sits in with carby cleaner too.
    After this, reinstall everything and reset your pcm by removing the engine fuse for over 10secs. When you start the car you'll want to give it a good hard drive for at least 15mins letting it idle every now and again for a period.
    If it doesn't improve after that then you'll have to start looking at having the IAC valve tested/replaced.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Cheers dude I'll give it a go in the morning.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Is there anyway to test it as i put a different one in and it's still the same, or should i just do a computer check?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    IAC Valve, it was from a car that was running fine before i parted it out.
  1. Stalling (auto V6) when changing from reverse to drive. Help!
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 07:32 PM
  2. strong joilt when put into drive from park or reverse
    By cruzn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2007, 09:45 PM
  3. VS wanting to stall from drive to reverse
    By silvr6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2006, 04:38 PM
  4. VR SS STUCK IN drive no reverse
    By muffman001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2005, 10:34 AM
  5. bad idle in drive and reverse
    By VSIIBerlinaL67 in forum V6 Development And Modification
    Last Post: 25-08-2005, 12:13 AM
