Results 1 to 13 of 13
Thread: Urgent VS Transmission Help Needed
    Commodore / Berlina
    Sep 2009
    Default Urgent VS Transmission Help Needed
    I brought a Holden Commodore / Berlina (3.8 eco) 1995 or maybe 1996 around 6 months ago. Just brought it up to road standard, 4 new tyres and put in a 2.5 exhaust. The car has been running great, till late...........
    I did a little paddock bashing at a friends place, nothing major and the car went sweet for about a week after that then the trans started going weird - Park = Park, Reverse = Nothing, Neutral = Forward, 1/2/3 = Forward. So, no reverse...
    Gets odd though, after around 2 days reverse came back? the car went sweet for around 400kms them went back to the same problem.
    I checked the trans oil and it is low so I am going to put some more in tomorrow, I spoke to someone on the phone and he thought I need a new gearbox??
    No error lights have ever come on the dash either!
    Urgent help please, I have an 800k drive coming up in 2 days and I really dont want the trans to go on the way...... Any ideas????????
    HICOMPVN's Avatar
    HICOMPVN is offline Wanting That Lil Bit More
    VN Commodore Executive S1
    Mar 2006
    S.E SUBURBS
    sorry dude, your gunna have to look for a new tranny, sounds like the reverse neutral solenoid could have shat it'sself, and the low oil wouldn't have helped when paddock bashing
    Commodore / Berlina
    Sep 2009
    Damn! what is a reverse neutral solenoid? So putting new oil in wont help? Will it just be that gear that's gone, will it be okay for me to drive the 800kms or will the other gears progressively go????
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Have a good look underneath where the electrical connector joins the transmission...possibly this got damaged in the paddock (stones/grass etc) and is causing an intermittent connection. If a solenoid has gone it should log a code and go into Limp Home Mode. If it was the sunshell gone, reverse would not have come back.
    I wouldn't slash my wrists yet...... top the oil up, throw a can of treatment (any brand though dearer the better) and keep your fingers crossed. Treat it gently and don't forget your phone! If you have time do a filter/oil change on the trans.
    Good Luck.
    Commodore / Berlina
    Sep 2009
    Thanks for the info, where are log codes displayed? do you need to hook some diagnostic tools up to see what the code is or does it come on the dash?
    How does one go about doing filter / oil change on the trans, is it a matter of removing the driveshaft and draining or is there a sump? I should really look for myself but that involves getting a jack / axel stands...
    It just seems to me like all the gears have god mixed up or something, it's almost like reverse is neutral now and neutral is drive.. I dunno.. Toped up the oil with some expensive stuff, need to get some treatment still though. Im gonna take it for a good drive with the new oil and see if anything changes.
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    make sure your selector linkage isn't loose or has slipped - adjust it if needed
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    you don't know if there's a sump on your tranny ? Maybe that is the problem, your sump is gone !!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check error codes follow this link:Checking error codes VR/VS (Revised)
    As scozz76 says; check the selector linkage (get under divers side and locate selector arm on side of box - see if it's loose/bent) ........and the wiring as previously suggested. If the paddock you bashed had long grass/scrub it may be damaged.
    Do a search on "changing transmission fluid" on this forum for the instructions on changing filter/oil.
    It's not rocket science as long as you think about what you are doing.
    Good Luck.
    VS Accliam Series II V6
    Apr 2009
    Mount Evelyn
    ok i dont know if its just my amazing gearbox but mine did that, and it went back to normal, and has never gone back to doing that after 20,000ks, i also snapped my park gear while wheels were spinning on stands and a mate forgot to brake and put in park, but then 2 days later it started working again :P
    although when in a gear, it does neturalise until the motor catches up with the tranny, well spins in sync with it,
    like if im in first and accelerate to 50 and ease off it'll neturlise, then when i accelerate it neturalises until it get backs up to rpm for 50km/h and goes again
    but yer need to change the tranny, so any guides??
    LOOKING TO BUY A NICE BODY VR SS MANUAL!!, CHEAP!!!
    ENGINE DOESN'T NEED TO BE THE BEST
    PROJECT CAR!!
    smoken_VS is offline Perth wa
    acclaim vs 3.8L v6 1995
    Nov 2009
    miami wa
    1996 Vs Commodore Series II V6 Auto
    Dec 2009
    South East Melbourne
    Quote Originally Posted by greenacc View Post
    lol i found that quite funny
    slipstream001 is offline -=Slipstream=-
    VR Senator II
    Jan 2007
    Werribee, Victoria
    sounds like the gear selector link could be bent as the selector turns its possibly out of line, is it hard to get it into park ? because if its bent upwards then the distance will be shorter therefore putting the selector into park or maybe 1st will mean stretching the bent rod. if the solenoid is gone in the valve body wouldn't replacing the solenoid be a possible option ? also there are a few electrical connections inside the gearbox that possibly ( though not much of a possibility ) you may have knocked loose, if the main plug has been knocked loose then that could be another problem. the gear selector linkage is on the passenger side near the back of the box you will see a thin round rod, the main wiring plug is on the drivers side ontop of the oil pan you might see a round plug with a rubber boot. also changing the oil is a matter of unbolting the 100000 bolts around the trans oil pan lowering it carefully and getting rid of the old oil, buy a trans service kit and you will see the big plastic thing which is the filter, pull the old one out gently if the rubber seal stays in the gearbox leave the new one off. tap it gently with your palm till its seated properly, clean the trans oil pan and dry thoroughly before it goes back up then refill with oil. all you need is a 13mm socket for the whole job
    vs commodore
    Oct 2009
    Tamworth NSW
    If the old seal doesnt come out when the filter is removed,you just gotta pull the old seal out.I carefully collapse the thin metal part of the old seal inwards with a screwdriver and it comes out easily.Better off using a new seal with a new filter,especially when theres one there already supplied with the filter.I just put some new fluid on the new seal,push it onto the filter and push the filter and seal back up into the trans firmly.
  1. Urgent help needed!
    By spd_dmn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2008, 06:32 PM
  2. Urgent Help Needed
    By greenvs in forum Electrical Wiring / Questions
    Last Post: 18-02-2008, 05:14 PM
  3. Urgent help needed
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2007, 08:20 PM
  4. urgent help needed!!!
    By speedracer006 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-02-2007, 05:38 PM
  5. Urgent Help Transmission
    By daggett in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2005, 08:40 AM
