I have brought what should be a stage 3 cam made by C.O.M.E Racing for my ecotec. It was all a package with the ported + polished heads and memcal. only thing is i measure the lobes and altho u can easily tell the duration of the lift is longer, its not as high. isn't this the whole point of a Cam higher lift and duration??
Thanks in advance.
camshafts are black magic simply measuring it will tell you nothing of the duration and lift unless you really know what your doing .
I have changed a can over in a datsun 260z the one i was pulling out had power from 1500rpm to 4500 rpm, the one i put in looked no different but made power from 4500rpm to 9000rpm.
Cheers Doug
Float like an elephant sting like a tree clubsport hits what doug does'nt see
ok good point i guess cheers.
