Results 1 to 11 of 11
Thread: VR strange bad vibration
    VS 5L UTE - VR V6 5SPD
    Oct 2008
    bayswater
    Angry VR strange bad vibration
    hi ive got a 93 vr manual v6
    just put a new exchange v6 in it , got flywheel machined, new h/d clutch
    put it all together got it cranked ova and it has a unbalanced feeling inside the car.
    it's there when u rev it stationary clutch in/out so its not in the gbox or tailshaft or diff.
    im thinking its either unbalanced flywheel or motor, could the wrong harmonic balancer b an issue? it came with the new motor. the wobbleing/ unbalanced feeling is there when the revs go up and down. any ideas???
    im guessing my best option would b removing gbox and clutch and fly and run the motor without the fly and see if the unbalanced wobble is still there.
    also the motor has a cam sensor plug so im guessing its a S11 and my vr is a S1 would that effect anything??
    any1 had similar problem or any advice
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'm sure you've checked already but are you sure it's not ignition or injector related? Also can to view the flywheel whilst it's idling to check runout?
    Oct 2008
    bayswater
    yer well i think it is missing aswell so im trying to figure out that problem too.
    can u get new coil packs?? wat else effects the timing
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    First thing I'd do is check that your ECU is the correct one to run the S2 motor plus if the ECU is for the auto I think you may have problems there. The miss will have to be fixed before you look at balance problems (which probably won't be there when idling smoothly)
    Do a search on this forum as there has been heaps written on similar conversion to yours and the problems you are having sound familiar. The timing can be affected by the CAS, DFI, ECU, leads plugs etc but in your case I'd go the ECU route.
    Good Luck.
    VR Berlina S2
    Aug 2009
    pretty sure i read somewhere, manuals dont run CAS's or something ?
    selling vp calais wheels with 97% rubber hardly used!
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    manual doesnt run a cam sensor they all run a cas
    Oct 2008
    bayswater
    this isnt a manual conversion its a factory manual
    has new plugs leads
    dunno about teh cas or the coils it has a miss with teh old motor aswell
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    OK - probably ignition related so first double check all plug leads are correctly fitted to the plugs and the coils.
    Did the new engine come with coils or was it bare?
    Oct 2008
    bayswater
    bare used the 1 i already had but ive changed with other 1's my mate had with no differance
    cas sensors seem pretty cheap maybe ill change that. dam cars!!
    VP Executive R-spec
    Jan 2005
    Oct 2008
    bayswater
    the engine builder put a ecotec harmonic balancer on it. all fixed now
  1. Strange, strange problem.
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 05:26 AM
  2. VN Vibration
    By bush_basha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-12-2005, 05:02 PM
  3. vibration
    By remmie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-08-2005, 06:29 PM
  4. vibration in vt
    By selvag in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-02-2005, 08:00 AM
  5. bad vibration
    By marky mark in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-12-2004, 01:45 PM
