Results 1 to 13 of 13
Thread: Compression ratio
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Compression ratio
    Is there a way i can calculate compression ratio from a kpa reading? I have about 1345 kpa on all cylinders.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    wait.. what? No...?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    9.4:1 is standard.
    what are you trying to work out? if ur has had work done or?
    Dec 2008
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    how do you work out compression from a pressure test?
    The hall of fame:
    ಠ_ಠ
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you cant ......
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The book says "min cylinder compression pressure 689Kpa at 9.35 CR." That's less than half of what Maldotcom2 has!
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    hako, i have the same figures in my book, quite possibly comp has been raised. unless the gauge is screwed?!
    Dec 2008
    Hako i read that part of the book too, hence why i'm asking. There are some online calculators to work it out but they required heaps of inputs like bore, stroke, etc. Thought someone might already know their figures so i can get an idea of whether it's normal or not.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    that is the worst case reading for tired old engine needing repair ide say
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Some time ago, Greenfoam answered a query by calaiscruzer <<<My mate has a vn 304, running 10-1 compression.
    If we did a compression test, what should the results be around? >>>
    Greenfoam's reply:
    <<<About 170 at a guess, depending on what cam is in it (but a correct cam for 10:1 will be about 170)>>>
    Hope this helps.
    ps...that"s PSI....not Kpa!
    Dec 2008
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    a 5L has a compression ratio of 8.4:1
    cant find compression test info thou
  1. Compression Ratio?
    By shanna72au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2009, 09:06 PM
  2. Whats my compression ratio?
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2009, 01:32 PM
  3. compression ratio of my efi 355
    By eaton v8 in forum V8 Development and Modification
    Last Post: 19-10-2008, 08:10 PM
  4. Compression ratio
    By geardys in forum V8 Development and Modification
    Last Post: 04-11-2007, 07:11 PM
  5. compression ratio
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-04-2007, 11:10 AM
