Results 1 to 7 of 7
Thread: 2500 rpm for 30 seconds reset
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default 2500 rpm for 30 seconds reset
    I just reset the computer in the VR (V8) and need to know if I should run it for 30 seconds at 2500 rpm like the VN V8.
    jujibelly's Avatar
    jujibelly is offline ERROR_PATH_NOT_FOUND
    Vr Commodore
    Apr 2009
    Melb
    VS executive
    Jun 2009
    umm, if i didnt do this last time i had the battery disconnected should i? i just drove normal straight away.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Another urban legend. Just drive the car as normal...the ECU constantly updates/alters parameterss all by itself.
    VP Executive R-spec
    Jan 2005
    I've changed my memcals more times than anyone can count, from vn tunes to vr tunes to vn tunes. sure the old IAC reset theory works but it DOES reset by itself with a quick burn around the block. And unless you are moving from one kind of tune to another you don't need to do it at all. I see Dr Bob still believes this is a true story but I can't agree since I don't see it on my own car
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I agree that it's not absolutely necessary as it will reset when you drive it because it will go over 2000rpm for 10 seconds anyway. All it does is reset the IAC, but it doesn't hurt to do it before you drive it, just to get it idling properly.
    Visit my Facebook page
    undar8ed1's Avatar
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Ok sweet, pillzor just don`t do it to the engine when cold.
  1. Easiest way to get 0-100kms in less the 6 seconds??
    By Nzpure in forum V6 Development And Modification
    Last Post: 10-06-2009, 09:11 PM
  2. 0 To 200 In 6 Seconds
    By Dirbatua in forum Jokes/Humour
    Last Post: 10-02-2008, 02:52 PM
  3. Relay clicking under dash every 11 seconds!
    By robbo2007 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-10-2007, 11:31 AM
  4. vp 0-100 6 seconds flat WTF
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:39 PM
  5. Replies: 14
    Last Post: 19-09-2006, 08:45 PM
