Results 1 to 9 of 9
Thread: Cruise control questions.
    VS ute
    RefleX v1.2 Champion!
    Aug 2009
    Default Cruise control questions.
    Hey,
    I know this has been posted before, but i cant find a definitive answer.
    i have as S1 vs ute manual, no power windows, remote locking or cruise control.
    I want to install cruise control, and possible remote locking, but i would think that because i don't have any options, i wouldn't have the wiring loom.
    How can i check if i have the loom?
    What Parts would i need?
    Can somebody please link me to a guide for installing it.
    My 5SPD VS UTE!! Now wrecking
    Quote Originally Posted by Grennan View Post
    Aggravated Burnout.... How is that different to a normal burnout, does the guy have a frowny face? Seriously get ****ed.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Check where the spaces for the relevant fuses and relays are and see if there are connectors in them or if they are blank. If they have connectors you will have the loom.
    MY RIDE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The hole for the relay is in the fuse panel under the steering wheel - look at the relay diagram to locate where the relay goes - the look into the empty relay socket for cconnectors. The fuse will be there as it operates other items. Also look around the pass side strut tower for a spare multipin connector needed to connect the module. Pix attached where to look>
    also link to more pix:How do I install genuine cruise control on a vs executive?
    VS ute
    Aug 2009
    thats not really helpful because im trying to find out where they are,
    and im looking for a "This is how it is and thats that" answer, because there is no threads with a be all end all answer.
    what am i supposed to be looking for thats in that picture?
    if it does/dosent have whats in the picture does that mean i definatly do/dont have the loom?
    what parts are required if i do have the loom?
    What parts are rquired if i dont have the loom?
    VS ute
    Aug 2009
    if my car doesnt have the harness, would something like this be easier to install?
    AUDIOVOX ELECTRONIC DASH-MOUNT CRUISE CONTROL - CarParts Quality Discount Parts and Accessories
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Jamie-b View Post
    You asked ""how can I tell if I have the loom?" which is what I answered. If you look in the fuse panel under the steering column, there should be a space for the driver's window relay or power window relay, see if they have silver connectors or if they are blank. If you don't have the decal listing the fuses and relays then I can't help you.
    As for cruise control look in the engine bay, around where the cruise control module would be located ( on the passenger's side I think) and see if you can find a spare plug where the module would plug into.
    MY RIDE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    That's a Yank site so freight will cost a bit more - the Audiovox is marketed in Australia as the AP150 - sells for about $215 delivered (Ebay).
    Re your other questions, read the post I sent yesterday at 8.45pm as it contains all the answers you need.
    VS ute
    Aug 2009
    yer ive seen em on ebay, but i dont reli wanna spend 215 buks on one..
    im sure postage couldnt be 100buks from the other site
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Price has gone from the Yank site??? also the guarantee is doubtful. I recently installed an AP150 on a VT Commodore - took about 3 or 4 hours - hardest part was attaching the magnet to the tailshaft.
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. vs body control module questions
    By GTS2 176 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2009, 09:10 PM
  3. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. Traction Control Questions
    By VXCalaisV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-08-2005, 06:23 PM
