Results 1 to 6 of 6
Thread: steering problem. please help
    VS Commodore
    Jun 2009
    Frankston, Vic
    Default steering problem. please help
    i finally got the statesman dash in last night but when i started car up today everything seemed fine until i got to a corner. basically theres movement but i have to turn heaps to get little wheel movement. its like the power steering has gone or something. need to fix it asap as ive got somewhere to be. please help
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I think you're right, the power steering is gone. But it aint going to be a quick fix. Find another way to get where you have to go.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VS Commodore
    Jun 2009
    Frankston, Vic
    all i did was replace dash though. couldnt have stuffed it that bad. where can i go to get it fixed? and how long u rekon it would take?
    VS Executive
    Oct 2008
    Balwyn, VIC
    Quote Originally Posted by fergie_vs View Post
    I've had quite a few steering problems so I'll relay my experiences with you as your problem sound similar. It could be the PS pump, low fluid levels in your ps reservoir, the PS rack, the high pressure hoses, your drive belt. Pray its just your drive belt, $30 fix and you can do it yourself. Check the indicators on the drive belt tensioner first, I got the pump, rack and hoses replaced by shoddy mechanics trying to milk as much money out of me as possible before I started to learn about my car and realised it was just the drive belt. Check your ps reservoir. Check for leaks etc.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Check your fuses, also do an ECU reset, disconnect the positive battery terminal for 10 seconds.
    Visit my Facebook page
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Despite the Statesman dash, I gather you still have the VS standard power steering?. If so, and going from your description: "basically theres movement but i have to turn heaps to get little wheel movement"
    is it possible that when you replaced the steering wheel or column you have not engaged the splines correctly which could allow what you describe.
  1. VR Steering Problem
    By combatantsomeone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2009, 10:15 PM
  2. Need Help. steering problem.
    By kapzi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2009, 05:31 PM
  3. vs ute steering problem
    By danos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2008, 06:46 PM
  4. VP Steering Problem
    By Cogez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-09-2006, 09:23 PM
  5. Steering Problem
    By Spyper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2005, 08:29 PM
