Results 1 to 11 of 11
Thread: vs commodore overheating
    VE , hg premier
    Sep 2009
    Unhappy vs commodore overheating
    just after some advice!
    my 1996 vs commodore v6 manual doesnt want to stay cool.
    all of a sudden it has just stated heatin up over half way on the temp gauge.
    i was told maybe the thermostat and a raditor fulsh would help but niethier have work so far.
    just took it for a drive and whenever i stop at the the light it jumps up to half and when i turn it off and the radiator cap isnt even warm.
    praying its not a head gasket!!!!
    ne ideas??
    whats a price to get a head gasket fixed?
    Aug 2005
    Quote Originally Posted by hg premier View Post
    ne ideas??
    I got the same problem got quoted $1200-1500
    also i hear a cheaper solution, something called Chem-i-wield
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It may be normal. Commodores usually run at around 1/4 to 1/2.....then when you stop at the lights with no airflow thru the radiator the temp gauge rapidly climb up to 3/4 when the fan will cut in and temp will drop fairly rapidly to 1/2 or less.
    If it was overheating the engine would smell very hot, you would be using coolant plus whenever you switched the motor off coolant would probably be forced out of the overflow tank. So hopefully it is OK.
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    mine does the same thing and stays cold i have a slow leak but fill it every mornning but temp goes up lots but car is cold its ok just dont drive if it stays at the red mark
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    check your fan is working on both high and low speeds, and try bleeding air out of cooling system using the bleed valve on top of the thermostat housing.
    vs clubsport
    Mar 2009
    brisbane
    When it is ''over heating'' pop the bonnet and squeeze the top rad hose does it feel really hard and burning to touch or just hot and you can squeeze it a bit if so it is fine if it is very hard and burning it is over heated if it is very hard and cold you have a blockage somewhere
    PS sorry for the grammer im tired
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    vs executive
    Jul 2009
    phillip island
    Quote Originally Posted by greenacc View Post
    does that valve just let air out and when it starts to get water/ coollent there close it
    greenacc's Avatar
    VE Berlina
    Jul 2008
    HamaTime™'s Avatar
    HamaTime™ is online now VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    It's normal in certain situations as described as above...
    Ecotec's do like to heat up to about 3/4 before the fan kicks in and the temp will rapidly go down.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    commodore
    Aug 2009
    australia
    my vr used to overheat i found it was the wiring just under the relay in the engine bay had melted stopping the thermofan from working dont know if its common but its just another thing for you to check..
    just a VS exec..... and a VEss Ute
    Feb 2007
    mine used ot get real warm in just the same way, and i was told it was a head gasket, but i turned out i had a hairline crack in the top radiator hose connection on the tank. $100 for new one on ebay
    sorted
    apparently its pretty common coz they are plastic end tanks or somthing
  1. commodore vn overheating - help please
    By cliff_canon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2011, 02:08 PM
  2. VP Series 1 Commodore (Idle is too high?/Overheating problem.)
    By icePiK in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2009, 05:28 PM
  3. VP commodore overheating
    By abzy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2008, 08:48 AM
  4. Commodore OverHeating
    By hzdaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 11:39 PM
  5. VX COMMODORE thinks it is overheating
    By HoldenOwner in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-12-2007, 08:39 PM
