hey is a cruise control modgle and cable and wireing from a vr the same as a vs?
cheers
Actual stepper motor Module beside air box yes ...cable from module to throttle body No .....wiring yes but if your car uses a low series bcm you will have to change it to a mid series to get the on/off button on the stalk to work or put the on/off switch somewhere else or go to the extremes like I did of making up a latching circuit in post 4 of this thread to go in its place so it all works like it should....if you go the bcm change option ,the grey and grey/green wires for cruise control will be different terminal numbers on plugs that go into the bcm from vr to vs.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
ah ok awsum, i checked what type of bcm i had a while ago but forget, think it was mid? i have teh wireing for it already (series 2 vs with abs) otherwise ill do what u sugested hehe
cheers![]()
sorry to but in, but can a v6 cruise control module be used in a v8??? is there a difference?
VSIII SS UTE
C.O.M.E 355
(WANT BOTTLES FOR IT)
thort the v6 and v8 moduals were different? maybe its teh cables lol
anyway i installed cruise today, hardest part was installing the modual as i had to drill teh holes, either way it was a pice or piss to do, eveything works, just gotta wait till i am off me suspension to use it lmao, (me dad tested it for me)
