Results 1 to 3 of 3
Thread: Cruise Control On Manual VR SS sedan
    VR SS S2
    Dec 2008
    Newmerella
    Default Cruise Control On Manual VR SS sedan
    I have installed all components need for the crusie control on my manual including stalk, crusie module cable and bracket, both brake and clutch switchs in series. Now when i hit the on button the bcm is clicking but nothing is coming up on the dash. I used a test light on the module plug and when i hit on (the stalk) i find i get a extra pin with power at the module but nothing will work. I have upgraded the BCM to a vr clubsport one with is a mid number one. Is there a relay or somthing need for the crusie control to work or do i need to do some re-wiring. All the plugs were there for all this to be plugged in. No wires i have added.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You need a relay which goes under the steering wheel where the other relays are - check the fuse/relay location instructions on the drop down panel and look for the location of the cruise control relay - I think it's to the left of the flasher relay. It's just a normal small relay identical to others already fitted.
    Good Luck.
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    I don't know about the relay somewhere under the steering wheel as I didn't need one when I installed mine.
    Did you connect up the dash lights? The 'on' light should come on when you have power going to the cruise module. The power should come from the BCM if connected correctly and the on/off switch should connect to the BCM while the acc/deceleration buttons go directly to the cruise module.
    There should also be a wire from the cruise module to the dash to indicate cruise is active.
    For the pedal switches, you will also need to connect into the brake light switch as a secondary backup. This will be a separate wire to the clutch and brake switches.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. VR SS Sedan Manual Crusie Control (HELP)
    By mectec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2009, 08:27 AM
  3. cruise control in manual vn
    By Clunt in forum Electrical Wiring / Questions
    Last Post: 04-01-2008, 09:39 AM
  4. Help! Cruise control for VT 5.0L manual
    By wilko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2006, 08:16 PM
  5. Cruise Control in manual
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-07-2005, 11:51 PM
