Results 1 to 4 of 4
Thread: vs 5ltr heating up!!!
    VS v8 manual Calais, Ve ute, 68 Hk Holden v8
    Aug 2009
    coalville, vic
    Exclamation vs 5ltr heating up!!!
    hey everyone
    my vs 5ltr ute s2 normally runs about 2marks up from cold on the temp guage but when i was in slow moving traffic the other day and was 28*c had the aircon on and the temp guage went to the 4th to 5th mark really quickly.
    is that normal? that thermo fan for the aircon does that come on when the car gets to hot when the aircon switch ISNT on?
    the radiator was replaced last year by the previouse owner and still runs a stock thermostat
    also i know u can buy twin thermo fans of a au ford that work really well, one comes on at 70*c and the other at 90*c is this worth it?
    also can u take the waterpump fan off and put in the two thermo fans off a v6 in?? cause my old vr v6 they worked awsome on the v6, i rekon there is enuf room,
    any advice would be great
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    "slow moving traffic the other day and was 28*c had the aircon on"
    Pretty much worst case senario for your cooling system. esp on a v8 engine.
    You shouldnt be worried about thermo fans, you should be worried about a full system flush. Take the radiatior out and give it a good clean to get the shit out of it, and then run some inhibiter through it for about 10mins, then flush that and then fill it up with coolant. once you have done that and it still gets hot, then start looking at thermo fans. You really should be doing this ASAP in time for summer otherwise you are going to have some serious trouble.
    47 made with the 185i engine $62,500 new
    35 made with the 215i engine $73,500 new
    vr caprice
    Jul 2009
    Quote Originally Posted by pedrotski View Post
    Coulnt of said it any better,as for the Au thermos they are a unreall ive just put some on. Easy as to install only took me 2 hours wack on a tranny cooler if ya got a auto too makes the job heasps easier. Great on those hot days my car never goes over 1/4 now air con is heaps cooler too!!
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    try replacing your thermostat before you get to excited about anything and a radiator flush.
    Reaper
  1. vz over heating
    By tommo25 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-01-2009, 04:59 PM
  2. Heating VS
    By EmmY957 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2008, 09:22 AM
  3. heating
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-07-2006, 08:31 PM
  4. Heating help
    By Holden_Mechanic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2005, 06:21 PM
