Results 1 to 9 of 9
Thread: VS Ute Central locking interior light coming on only???
    Aug 2008
    Default VS Ute Central locking interior light coming on only???
    hi guys,
    i Just purchased a VS series 1 ute, v8 auto, when i press the central locking on the key, the interior light comes on, and the flashing red light in the dash goes off. but nether locks, unloack, you can press the locks up and down and hear the actuators working, could it mean i need a new remote? due to flat battery? strange i thought if its flat batteryin remote it wouldnt even activate the interior light???
    any advice help, thanks.
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    its a series 1 thing they didn't have cental locking as far as i know. mine does the same
    Aug 2008
    Quote Originally Posted by fuzzy2308 View Post
    strange, why does the remote say doors on it?
    is it just for the imobiliser???
    Aug 2008
    just looked in red book and it says, VS series 1 have central locking as standard features??
    bugeredif i know, mabye job for a sparky!
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    check the solenoids in the door are working properly, I needed replacement ones and got two from the wreckers for $55.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
    sounds liike ur motors are gone in ur doors ,mine Stato does same with rear doors
    VS Commodore series II
    Mar 2009
    Port Macquarie
    mate when its wet weather some of my doors make a noise like there trying to open or close(lock) light comes on. i doubt they would have put a button on the key just to turn light on and enable immobiliser. but im sure you guys would know more. i just took trims off and fiddled with the locks pulling them up and down. they work now but i always check them to be sure.
    Sep 2008
    VR 5L ute
    Oct 2007
    None in my ute VR 5L. Im going to add harness from bcm to door locks
  1. vs s2 v6 central locking
    By davidbenjamin70 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2009, 08:22 PM
  2. VZ Central Locking
    By Trevor 062 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-06-2009, 11:51 PM
  3. Put new central locking motors in but central locking still doesnt work???
    By richardbignutsonstato in forum Electrical Wiring / Questions
    Last Post: 15-02-2009, 03:41 PM
  4. central locking?
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2007, 10:49 PM
  5. vp central locking
    By milesy69 in forum Electrical Wiring / Questions
    Last Post: 28-09-2007, 08:08 PM
