Results 1 to 8 of 8
Thread: About a previous post for others knowledge
    Supercharged Vr V6 Stroker
    Sep 2009
    Exclamation About a previous post for others knowledge
    I had a issue a bit ago with my vr Calais, the auto would intermittantly stop changing gears properly and wouldn't kick down when you gunned it, after turning the car off then on again it would be fine for a few k's at least sometime up to 100 k's
    I was told a heap of things which i checked twice to ensure i didn't miss anything ( computer, wiring harness, auto it self, Pressure solenoids shift solenoids etc...)
    Anyways nothing helped till a brain storm came along, Thinking to my self how does the car know when to change gears, TPS (Throllte Position Sensor), I headed off to the reckers and got one for $10, Plugged it up, bolted it on, turned on the appy with efi live and checked the signal it read .64volts straight away, with 4% throttle, My old tps only read .39 volts @ 1% throttle, to cut a long story short it fixed the problem,
    The car also used to miss every few seconds and it fixed it aswell, purrs like out of show room,
    The only other thing i did was
    1, Reset the Throttle position sensor, TURN CAR ON TO IGN, RESET THE TPS AND TURN OFF FOR 5 SECS AT LEAST, NOW READS .64VOLTS @ 0% THROTTLE, PERFECT
    2. RESET THE IAC SENSOR, TURN CAR ON TO IGN, RESET THE IAC SENSOR AND TURN OFF FOR 5 SECS AT LEAST,
    I done this using efi live professional and worked a charm, PLEASE NOTE AS FAR AS I AM AWARE THE TRIAL VERSION OF EFI LIVE DOES NOT DO THESE FUNCTIONS EVEN THOUGH IT SAYS IT DOES,
    Once again thanks to all for their help Especially DOCTOR BOB for his many emails,
    Cheers and god bless Just commodores
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    So EFI Live has a function that resets the IAC and TPS? (I've not used EFI Live)
    and 3 Dangerous non ABS VN's
    Sep 2009
    Yeh, its got heaps how macro's, just be sure you know what your doing before doing it, (dont wanna screw things up,) oh it has to be EFI LIVE PRO
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    can enguage and disenguage A/C ,add spark ,bypass spark advance,turn check engine light on and off to test it,clear tr5ouble codes ,dump memcal to file, command any gear lockup tcc turn off fuel pump can do heaps with it
    Sep 2009
    VS Berlina
    Feb 2007
    Sep 2009
    not without some sort of scan tool, or pc program that supports it,
  1. what do you like/dislike about your VE compared to previous ride?
    By Pete in Perth in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-08-2009, 03:30 PM
  2. Singature not showing on previous posts
    By azzfox in forum Site Feedback / Site Problems
    Last Post: 26-05-2008, 04:01 PM
  3. how to find out previous owners
    By iRiot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2007, 07:45 AM
  4. 1993 VR Utlity (My Previous Ride)
    By wazza 42 in forum VR - VS
    Last Post: 25-02-2006, 03:38 PM
  5. My Previous Commodores
    By Rossgo79 in forum General
    Last Post: 11-09-2005, 07:19 PM
