hey guys ive just run the flash test and these codes came up
Code 16 - Coolant temperature Sensor voltage unstable
Code 31 - Theft Deterrent Signal missing
Im just wandering if anyone knows how to fix these faults because i have no idea how to. thanx
theft deterrant signal missing... mine does this occasionally (sometimes the key doesn't contact properly) 5 years I haven't had reason to fix it
coolant temp sensor i'd look at wiring and connections first, make sure it's contacting properly, change sensor if needed (long process but easy work)
if none of that works, i have no idea what to do next
WTB VR/VS FACTORY HEADUNIT BRACKETS PM MEOriginally Posted by MY-42-VT
Probably best to clear the codes (pull engine fuse for 30 secs) and then check again in a week.
