Has anyone here done this,im thinking about doing this so i can modify the centre console to better suite some ideas.
WTB:VR/S HSV 250km/h speedo cluster
Just a note of caution: you will need an engineers certificate to make it legal.
ive seen it done on a VS that was at the wreckers, it looks like they used the leaver out of a HQ/HZ
pretty sure the utes with a bench seat has the handbrake next to the drivers seat
Hmm,my bad,im looking at doing VT-onwards style,left of the drivers seat
2" can make a big difference in some things. Subtle changes are sometimes better than wild mods.
Use the handbrake out of a VT.
i reckon youd have to weld a whole piece of the VT trans tunnel into your VS tunnel?
The VS hand brake lever is within the centre console piece of plastic,right next to the passenger seat. The VT hand brake lever(sum1 correct me if im wrong) is positioned between console and drivers seat.
If i can get the VT set up in my VS,there'll be heaps of space to play with between the console storage compartment and the gear shifter area. Cover the old handbrake space with new plastic and drink holders or something would be a piece of piss to fit in
The VT handbrake is recessed into the console on the right hand side, and probably takes as much room out of that side of the console as the VS one does on the left hand side. The VT handbrake is not placed outside the console area as you are suggesting. I would think you would be going to a lot of trouble and not gaining any additional space at all.
but i dont use the side of my console so why wouldnt get extra space by moving the lever to the side. either way i'll sus it out and see wat happens.Was hoping it wouldnt be overly hard but damn wasnt i wrong
i think i get wat u wanna do. It does leave a fair amount of room there once u think about it. Here is a quick photo chop
Wrecking VL factory V8 only a few bits left still have full dash/crash pad
and have a vk 202 motor and 5 speed Make an offer want it gone
Yeah,I have to admit that does appear to open up a bit of space - certainly more than I thought. The work involved on the floorpan will be extensive though.
Thanks buddaboy,now people should get a better understanding on what im trying to explain. Ive seen it done before and im on a 3 month suspension which gives me time to do some research before i decide to do it or not. A trip to a wreakers should give good insight too. Ive always wanted the centre console to be more useful,change power window buttons to the smaller/more compact VY/Z style etc and moving the hand brake lever which is possible,would give me heaps of options. As said tho,it'll have to be researched a lot. I just wish i knew someone who's done it.
Is yours an auto if so, Who needs a handbrake???
thats ok.... ^^^^^ its not the best idea 2 leave it in park. Especially if its on a hill
Umm 1 no its a manual and 2 im fairly sure the law has a thing for handbrakes,RTA would chew yo A-hole if they knew it didnt work,they'd have a fit if it were missing
