Results 1 to 4 of 4
Thread: Boot lever rooted
    -ToM-'s Avatar
    -ToM- is offline Bow Down to the Emperor!
    VR Exec [EMPIR3]
    Jan 2008
    SA
    Default Boot lever rooted
    Ok, boot lever wont pop the boot anymore.
    Not good at this sort of fidgity stuff. Just after someone who could fix it for minimal fuss and on the cheap.
    What sort of place would i have to go to? Could a mechanic do it when i say took it in for a service? Body repair shop?
    cheers guys
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    spray wd-40 over the latch first. see if that fixes it.
    47 made with the 185i engine $62,500 new
    35 made with the 215i engine $73,500 new
    2001 VX Commodore Equipe
    Jun 2003
    Guys,
    My boot went the usual 'click' then 'clunk'.... it won't open.
    I had a look and the metal rod (10cm long) inside the boot lid attached to the actuator had sheared off at the boot lid latch.
    I was thinking... off to holden $$$$
    After looking at it I figured how to repair it.
    Hope these steps address your problem:
    1. Opened the back seat to release the boot with the emergency catch
    2. unscrew the two screws holding the silver latch.
    2.a. unhook the emergency release cable from the latch (stow it so it does not pull pack to far. WARNING: Do not pull the emergency release tag near the back seat when it is unhooked from the latch - it may end up behind the boot liner).
    3. unscrew the two srews holding the actuator motor inside the boot lid (undo the power cable prior to removal).
    4. unclipped the rod from the actuator (it will push out of the white end piece).
    5. took 1 x metal coathanger (the type from the dry cleaners)
    6. cut 12.5cm of coat hanger.
    6.a. you need a 10.5cm straight piece with the other ends bent at 90 degrees (off centre - check the current rod as a guide). I just measured the old one and matched up the bends/angles
    7. place the replacement rod into the acutator end, refit the actuator and hook the other end of the rod into the boot latch and rescrew it in.
    8. sorted!
    I can post some photos if it helps. Though it is very easy once you have a look at it.
    Bart
  1. drivers door rooted or what????
    By clazzza commy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2009, 04:48 PM
  2. Do I have a rooted gearbox?
    By voodoo VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2009, 11:44 PM
  3. Boot Cable Rooted
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2007, 08:35 PM
  4. Is my msn truely rooted?
    By VL Berlina 5speed in forum The Pub
    Last Post: 05-10-2006, 06:15 PM
  5. VX accelerator rooted
    By vanessaj in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2005, 04:59 AM
