Results 1 to 8 of 8
Thread: Bad Review of use: Lukey Filter with LPG and Cold Air
    VS S2 Exec Wagon 3.8L w/ Vy Auto Trans
    Sep 2009
    Angry Bad Review of use: Lukey Filter with LPG and Cold Air
    Hi, I'm Nathan, Work for only the best Auto Parts group in the Country (will not name to keep you guys guessing).
    My Car, 97 Series 2, 3.8L Wagon with mods such as LPG converison a month ago, VY Transmission installed when my VS carked it, and cold air intake.
    I decided to purchase a Lukey Air Filter with life time guarantee, you kno the whole buy a K & N thing and clean it and re use it..... Well Lukey was new and only hat to be hand washed with water, dried and re used.
    The Lpg appears to have had a bad affect on the styra-foam (material the filter is made of) and its become brittle and hardended.
    Cold Air Intake smashed it also, too much pressure at 120ks/h, holes right thru it, and only after one clean and dry.
    Right now my motor is running as rough as guts because I only looked at the rockers and lifter panel under the oil cap to change the oil and realised the sludge and dirt coming off my finger when i ran it under the rocker cover. Every Oil change before that the engine ran perfect and rockers were still showing carboned metal.
    So I'm guessing after I go back to Ryco filters and changing my Oil 3 times every 500ks to clean it, I'll be looking at replacing my motor earlier than expected due to my trust in Lukey advertising in their filters.
    Don't know what anyone else thinks about this, but I'm doubtful LPG will work with any filter brand. Cheers
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    I think you will find that lukey filters are made from polyester fibres ... not styra-foam.
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    how can LPG affect the filter if it in injected after it? you must have it setup incorrectly. filter to close to the lpg injection maybe or regulator hoses?
    47 made with the 185i engine $62,500 new
    35 made with the 215i engine $73,500 new
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Yeah I don't get it? Why is LPG going through the air filter in the first place?
    Appreciate the write-up and all, but you've created more questions than you've answered. I'm sure K&N filters don't react that well to hydrocarbons either by the way..
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    pedrotski's Avatar
    Jan 2008
    Mandurah
    Quote Originally Posted by TVR-161 View Post
    Lpg huh, backfiring would put some holes in the filter
    Well K&N have a filter that holds together in the event of a backfire. If you are using a stock filter and air box, the air box will eventually explode. If you take your car to a good tuner they will minimise backfire in the intake. Here is the setup i have on one of my VS Statesmans.
    Basicly, if you want to drive so hard that the car will backfire anyway, you should be on petrol not gas. Gas is more about economy than performance (unless multi point injection).
    If you are having issues with your gas system then you should really see a specialist that have a dyno.
    Sep 2009
    Hey guys,
    Cheers for the write up about it all.... Spoke to everyone about it. The backfire did occur, its been running very rich since the LPG was installed. (Was told the mixer recycles the air and pumps the waste back into the cold air tube before the filter hence my confusion). I dont drive it hard and if i do yes it is on fuel, the colder plugs recommended for LPG dont help for the fast accel either.
    About the filter holding up in the back fire... it was burnt polyester fibes that allowed the dirt and shit in. Not sure if the K & N will give much protection so I'll just go back to Ryco and check weekly.
    Happy Driving
  1. [VIC] Lukey Performance Air Filter VT-VY
    By Noy in forum Parts And Other Items For Sale
    Last Post: 17-01-2009, 06:29 PM
  2. Lukey performance air filter
    By Fr3ak+-- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-02-2008, 08:25 PM
  3. pod filter or v8 cold air box
    By yotaman in forum V6 Development And Modification
    Last Post: 31-08-2005, 10:20 PM
  4. Cold Air Induction & K&N Filter ?
    By NXNVR-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2005, 11:26 PM
Tags for this Thread
