Results 1 to 7 of 7
Thread: Will VN Live Axle shocks and springs fit a live axle VR?
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Default Will VN Live Axle shocks and springs fit a live axle VR?
    I have been offered a set of rebuilt monroe gas shocks and springs off a VN sedan, Im just wondering if they will fit a VR sedan. Both are live axle. I know the front strut tops are different, but is there anything else that might cause an issue?
    95 vs calais V6 Auto
    Aug 2009
    Dora Creek
    A mate of mine swapped ones out of his vs for vl ones and im pretty sure they were a straight swap, so as a guess id say that you can put vn ones into vr.
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    VR BT1
    May 2006
    South East Melb
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Quote Originally Posted by damageinc. View Post
    suspension set up is the same
    Thats correct, the only difference is the weights of each model and sthe springs are made to suit.
    Sometimes if the height you want is between 2 springs for your model then look at a model with different weight and work out which springs might work.
    Buying springs from wreckers can be quite cost effective even if you need to buy a couple of sets to get it right.
    I couldn't get the ride height in the rear of my VS wagon right so ended up using sedan springs and it was as close as I wanted it.
    Sure the load carrying is different between wagon and sedan but I didn't carry heavy loads anyway so didn't matter.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Ummm...no.
    Rears are the same, the fronts are different. Different struts, different springs. The V8 VN-VP fronts are the same as the V6 VR IRS. It all has to do with vehicle weights and spring rates. The will physically fit but will not sit the same as the correct springs nor will they handle the same.
    Visit my Facebook page
    VR Commodore
    Jun 2005
    there will be different offset. when u go lowered ur car .. i remember someone fit VN-VP irs on VR irs ... and the wheels go more inner side, not the outer side... its very good to stop the tyre get rubbing...
    as Live beam axle will be same. but maybe there have different offset, i guess so
  1. [VIC] WTB: Shortened shocks for live axle
    By MizzVR in forum Swap / Wanted to Buy / Trade
    Last Post: 30-08-2009, 12:02 AM
  2. In WA? Is your VN/VP live axle sedan too low? I want your springs.
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2008, 01:16 AM
  3. FS: Munroe gt gas rear shocks VS live axle
    By rawnrg in forum Parts And Other Items For Sale
    Last Post: 11-05-2008, 11:04 AM
  4. w.t.b lowered springs (f&r) VN-VS live axle
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-04-2008, 05:52 PM
  5. IRS VP rear springs into Live Axle VN
    By Steery in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-03-2008, 02:09 PM
