Results 1 to 5 of 5
Thread: manual madness
    VR 5.0LTR auto
    Sep 2009
    Default manual madness
    hi, i have been wondering for to long now i have been told that you are required to fully balance the vt vx ecotec in order to put a 5 speed gearbox behind can some body please settle this for me
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Im not sure what you mean by balanced. If the motor wasnt fully balanced, even with an Auto transmission, it would still tear itself apart at high RPM's anyway...
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    As said the engine is already balanced. I think what you're referring to is the flywheel. If you use a flywheel from a VN-VR (i.e. a solid flywheel) it will have a counterweight on one side for the external balancing of the buick engines. The ecotec is internally balanced (Series 2 Flywheel...). From that i deduce if you use a solid flywheel you need to have it rebalanced to be symmetrical.
    VR 5.0LTR auto
    Sep 2009
    ok thanks heaps i was reading after i posted that thread and further ead that the ecotec as you quoted are internaly ballanced so now we might just have to opt for the ecotec conversion for the vr then
    VR 5.0LTR auto
    Sep 2009
    ok one more, know i know that we might go ahead and o the conversion what would be the better, vn-vr s2 clutch and flywheel and as you stated get symetricaly ballanced or is there a flywheel made for the vt that is already ballanced. if so will the early pressure plate bolt up to late fly whel
  1. aaargh wtf help. k frame/control arm madness
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2009, 05:12 AM
  2. 4.00am madness
    By metalfossil in forum The Pub
    Last Post: 25-09-2007, 06:20 AM
  3. car park madness
    By xcop5l in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2006, 11:54 PM
  4. vc madness
    By brady in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-11-2005, 07:33 AM
  5. Madness
    By Bax in forum General
    Last Post: 24-06-2004, 07:01 PM
