Results 1 to 3 of 3
Thread: Piller Trim
    Jun 2008
    Default Piller Trim
    Hi all,
    I'm looking at re-trimming the headliner in the VS as its sagging badly and i'm just after some tips in getting the plastic pillar trim off without having it break as it seems to be stuck on quite well. Thanks for any help.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I used an old flat bladed bread and butter knife which doesn't have a pointy end - insert it behind the plastic and gently force the panel off - you will see that the plastic resists bending where the clips are so then you move the blade closer to the clip location. You'll break some as it's unavoidable. Trtim bits that get broken can be re-attached with contact cement or any suitable glue. I resorted to screwing one of mine back with a self-tapper and then put a 'screw cover' (from hardware shop) on top of the screw to hide it.
    The best bit of advice I can give you is to take your time!
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    i got the shits and broke mine
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
  1. Trim ?
    By WOODY'SVRSS in forum General
    Last Post: 08-07-2009, 08:42 PM
  2. [VIC] WTB: Red VN S Exterior Trim
    By Tibokan in forum Swap / Wanted to Buy / Trade
    Last Post: 07-01-2009, 03:58 PM
  3. is this trim still available??
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2008, 10:42 PM
  4. ve- ssv door trim
    By welly01 in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-02-2008, 08:06 PM
  5. VN & VQ Trim
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2006, 07:34 AM
