Results 1 to 11 of 11
Thread: VS Acclaim Thermo Problem ??
    CU5H1NG is offline CU5H1NG
    VS Acclaim
    Sep 2009
    Merrimac, Gold Coast
    Thumbs down VS Acclaim Idle Problem ??
    Hey guys,
    I have just bought a 95 VS Acclaim and have had it for a month now. All good till now...
    When I am at the lights or just sitting there on idle (in drive), my car will 'clunk' as if you are changing gears (say from Park to Drive) and im not doing anything. Then, the revs will climb to about 1200-1500rpm. You don't even have to put yor foot on the accellerator and the car basically drive foward itself !! Even up hills !! Took it to a transmision shop and found its not the gearbox. He drove it and it happened several times and he reckons its something to do with the thermo's coming on an off at the wrong/wright time
    The revs will only jump (and clunking occures) when the thermo fans come on
    If this has happened to you, can you please let me know what was wrong and how you fixed it?
    Thanks guys
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Are the thermo fans shorting out and sending voltage to places they shouldnt?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    vs clubsport
    Mar 2009
    brisbane
    Quote Originally Posted by greenacc View Post
    Sounds like your AC is switching itself on and off ?
    I agree sounds like your ac gas is low causing the compressor to cycle playing havic with your tired lazy old idle solenoid
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    VS Acclaim
    Sep 2009
    Quote Originally Posted by clubby_you View Post
    We rang back Burleigh Commodore and they said that maybe its your throttle body, it maybe dirty. I cleaned it yesterday arvo really well with some CRC throttle body cleaner and it was a bit sooty and had some carbon. Took for a drive last night and this morn and all is sweat!!!!!! Hopefully it was only a dirty throttle body.
    VS Acclaim
    Sep 2009
    back again!! it was all good for about a week and its screwed up again my mechanic recomended a whole new throttle body because maybe your htrottle sensor in the throttle body is clogged causing it to stick every now and then making the car rev high. put a new one and its still doing it . can anyone help....... (read top for better explanation) the car will still jump quite a few times and then the thermos will come off and the car will rev higher to approx 1500-1700rpm. it will stay like this unitil the thermo's switch on. i know some of you have helped but anymore suggestions please....
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Maybe it's the IAC that's mounted on the throttle body that's sticking - if so that will give a variable idle. No fault codes? Also check the vacuum hoses around the throttle body for splits.
    As an experiment, disconnect the connector to the coolant temp sensor (it turns the fans on) and see if the problem is still there. Engine may run a bit rich but will do no harm temporarily.
    VP Exec
    Jun 2005
    The thermos will come on in "limp home" mode i.e. if there is a major fault in the engine management - sensors, wiring. It's definitely worth checking for fault codes.
    Maybe try the "wiggle test" on the engine bay wiring too: move the engine bay and PCM wiring harnesses with the engine running to see if the fault occurs when a connection is intermittent.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    ^^^^I think cheap6 is onto somthing there
    Reaper
    VS Acclaim
    Sep 2009
    Quote Originally Posted by hako View Post
    the IAC was replaced along with the throttle body because that was the supposed problem, it was full of gunk and carbon. It was also checked for fault codes on the service i had a few hundred km's ago and there was none found. ill check the vacum hoses 2moro and where is the coolant temp sensor located?? is it near the radiator?
    ill try the wiggle test 2moro aswell and see if any happens. keep u informed
    thanks HAKO and Cheap6
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The coolant temp sensor is under the thermostat housing - it's the rearmost one - the other one in front with a single wire is the temp gauge sensor.
    Re the IAC - if the first one was really dirty maybe the new one is still picking up residual dirt from the throttle body.
  1. problem with thermo housing bolt up top
    By TRICKEDUP in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-02-2009, 07:25 AM
  2. thermo problem... maybe
    By platty in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-10-2008, 09:44 PM
  3. VX acclaim: Problem with a dealer PLS help
    By crucible82 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2008, 01:34 PM
  4. Thermo fans problem
    By Bent_6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2008, 11:32 AM
  5. VT 99 Acclaim Starting Problem
    By VTRob in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-11-2006, 01:26 PM
