Hello,
I currently have a VR Commodore that has a blown motor (V6) and a also have a VS SS that is written off. Can you please tell me what is needed to put the VS SS running gear into the VR.
Could you's please write me a list
Thank you Josh
is the vr a v8 or v6?
yeah the vr is a v6
can anyone help???
EDIT ok i understood the question now , here:
VR V6 to V8 Conversion Help needed
v8 conversion
V6 to V8 conversion
v8 conversion parts - motor box ecu loom kframe tailshaft lsd
More...
it sound simple that i may be in the end lol
just like mods to car or even simple things like changing oil uno you may not put the seal on the oil filter and you have a oil leak lol
as far as i know you will need
v8 k frame
v8
v8 gearbox
tailshaft
engine bay wiring loom
ecu
v8 dash cluster
brakes might be bigger on v8..?
v8 radiator
front struts and springs from a v8
Cant see it being that hard tho you will need a mod plate also not a prob if you swap every thing from the ss
Float like an elephant sting like a tree clubsport hits what doug does'nt see
CLUBBY YOU
is it only the wiring in the bay or the whole car???
pretty sure that the under dash is the same and the engine bay loom shouuld plug inot the loom but dont quote me
