Heres the scenario
My car randomly stalls.
V6 Supercharged L67
Ill start my car up it starts, then the revs just drop and it stalls
But doesnt get affected when im driving.
i can rev it but it doesnt like to idle
its not everytime tho.
thanks shane
try clean the Iac valve in the top of the TB and also check for vaccuum leaks
^^^^ yeah i'm with me too, on this one. It sounds like the idle air control valve... Take it out and see if it has come apart, if it has then you will need a new one
NEVER LATE IN A 355ci
Mine does the same thing,
Feels like rough idle at 600rpm when warm.
Stalls on me standing still sometimes at lighst then take a while to start again,
have replaced IAC no different & cant find vacume leaks...?
did you put a NEW iac motor in or second hand????. The reason i ask, is cuz i went thorught 3 second hand one before i got a good iac motor. PS clean the inside, where the iac shafts goes into, cuz the get alot of carbon stuck onto it. PS do you adjust your base idle???? that can also cuz it to stall
