Results 1 to 6 of 6
Thread: VR Running hot
    VS Clubsport
    Feb 2006
    Ipswich
    Question VR Running hot
    Hey just a question my VR if setting idaling for not too long 10 mins or so heats right up until the fan decides too work about half temp (not nice sitting watching temp guage going up) what could be the issue?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It could be the thermostat not opening when it should or a faulty temperature sensor.
    MY RIDE
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    does the temperature go down when the fans kick in? if so, it sounds like normal operation to me.
    While driving, the temp' will normally drop as there's air passing through your radiator. When at idle, there's no air passing, therefore the temp' will climb until the fans kick in.
    My first car didn't have a temperature gauge (LH Torana), I had no idea what the temp' was. I think these extra gauges are more trouble than good.
    Get into the habit of checking your coolant level, and unless you see a leak or your engine smells hot, I wouldn't worry
    Rufus®'s Avatar
    Rufus® is offline I Jizzed in my pants
    VR S1 S Pack, VX S2 Acclaim Wagoon
    Apr 2005
    The Marsh, Vic
    Wouldn't stress to much, as long as it drop when the fan kicks in.
    If it doesn't, check thermo and look for any leaks.
    Signage, Splash Backs and Display Systems
    "No, I'm not a pessimist. At some point the world shits on everybody. Pretending it ain't shit makes you an idiot, not an optimist."
    VS commadore V6
    Mar 2007
    Mine goes up to 3/4 in heavy traffic, I have flushed out the cooling system, new thermostat, changed the temp sender & temp sensor for the ecu, checked the temp sender wirring, bled any air out of the system, the water pump is good & radiator is good, there is no coolant leaks, relays are working properly as well, all of this made no differance to the temp guage, apparantly its normal for them to go either 1/2 or 3/4 on the temp guage before the low fan cuts in, it used to worry me but now if I am stuck in traffic I just switch the air/con button on and it never goes past 1/2 way in heavy traffic.
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    sounds normal, your car will generally heat up more idling then driving as there is no cool air blowing onto the motor/radiator. the eletronic fan acts like cool air blowing on the radiator whilst driving. you only really need to worry if it creeps above 3/4.
  1. VS running hot
    By HamaTime™ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-05-2009, 11:01 PM
  2. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  3. running hot...
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2006, 11:37 PM
  4. running way to hot ?
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-09-2005, 03:38 PM
  5. wants to keep running!!!
    By elffie75 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-08-2005, 06:19 PM
