Results 1 to 10 of 10
Thread: How do I fit mesh to front bar
    VS UTE S3 5.0
    May 2008
    Default How do I fit mesh to front bar
    I've just fitted my VZ Maloo front bar to my vs ute looks sic, does anyone know how to fit mesh behind the holes
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    That'd be... interesting. Looking forward to photos. I'm curious about the mesh too, would like to throw some incospicuous black mesh in my VS.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    usually they have little sections that pop riverts or screws can go into, i no i have them on my clubsport, but maybe you will have to glue it with some strong adheasive that would prob be the only way if you dont wanna damage the kit with screws and pop riverts..
    but i maybe wrong there could be another way
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    Putting brackets in would be the obvious way, but i wouldn't want to put holes in the bumper for rivets... I'd expect you'd need some pretty damn strong glue to avoid that though.
    Trayner's Avatar
    Trayner is online now L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    I was thinking about doing this to my stock bar too. guess you could bend/cut the mesh so it has tabs , and like then sikiflex it there ? i dunno lol
    BrAdAsS is offline Banned
    VX Executive A4
    Dec 2005
    Brisbane Northside
    yeah sikaflex...silastic... I cut the mesh to shape, just a bit bigger so I'd have room to bend it over the edges by 2". I used about 2 tubes in the caulking gun on mine and it looks messy from the back, but has been on for 4+ years without needing another look, but, can be removed with a stanley knife if need be.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    No, I did my vy grille and the part under the grille too. What you need to do is superglue some short pieces of wire about an inch long in place around the edges on the back. The superglue only holds the wire there until you can get some fibreglass resin and really get a heap of it on there. I cut small pieces of f/g matting as well for reinforcement then when it sets put another couple of coats of resin on.
    It is quite fiddly and will test your patience but is a good way of doing it other than plastic welding it. Obviously you then put your mesh in place and bend the wire over, mine came up awesum.
    Hope this helps, PM me if you need further instruction/advice.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    I used stick on cable tie anchors then used cable ties to hold it all together. You need to clean the area where you want to stick them otherwise they will not adhere properly. It's fiddly work.
    94 vr commodore executive
    Apr 2009
    busselton
    you can also cut it out to shape a big bigger for tabs as u said the drill tiny little holes and wire it in will be there for ever and looks neat easy to take out thats way i did on mine
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    I used fibreglass filler, actually incredibly easy, as the lads haev said above: cut your mesh wider than your vent holes and bend the sides around , then i mixed the filler with the hardner and pressed it all through the mesh holes onto the sides. Rock solid, Looks neat, Cheap & Easy.
    I've made her a Hold-On Commodore
    Foam Tuned 1995 VR Series II - 9psi Boost - Manual - FM Intercooler - 3" S/Steel Plumbing
    Super6 Injectors - Ceramic Wrapped Genie Extractors - 2.5" HiFlow Cat - 2.5" HiFlow Catback Exhaust with a 4" Dump Resonator
  1. mesh for front of car?
    By kazalex in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2009, 09:11 PM
  2. attatching mesh
    By MikesVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2006, 04:47 PM
  3. mesh grille
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-06-2006, 11:14 PM
  4. Mesh for VX clubsport front bar
    By harveyt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-11-2005, 05:19 AM
  5. Mesh
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-08-2005, 06:10 PM
