Results 1 to 10 of 10
Thread: VS Commodore won't start
    otis33 is offline Otis
    vs acclaim
    Sep 2009
    Christchurch New Zealand
    Default VS Commodore won't start
    Got a VS Commodore, the other day the wife took it out and it won't start.
    Though maybe cause the key is getting old as it doesn't work the remote entry anymore.
    When I turn the ke you can hear the relays clicking but nothing else happens.
    Any ideas?
    VS Series II BT1 wagon
    Apr 2009
    Jammed starter? Bad relay (doubt) or keyhead flat. Turn to ON and leave it for an hour (ON) then turn to START, see if it starts.
    VS Berlina
    Jan 2009
    NSW
    I had a problem like that.
    It could be the battery supplying enough energy to work the starter motor but not ignite the engine or the starter motor is dirty.
    vs acclaim
    Sep 2009
    Apr 2009
    Get a length of wood and put it on the starter, give the wood a whack with a hammer (solidly, but not hard enough to dent it), preferably with someone else turning the key at the same time.
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    is your battery flat? I'm talking about the car battery, not the keyhead. Usually there's enough to slighty activate the starter solenoid, but will fail under load.
    vs acclaim
    Sep 2009
    have tried to jump it so the battery is good to go, will try and give the starter a smash and see if that helps.
    richie351 is offline statesman driver n luv it
    VRcommodore
    May 2009
    w.a
    is it automatic? if so push the gear lever towards pasenger side n try start.. if stil doesnt work wriggle it around a little.. there is a switch stopping u from starting it in any gear.. n my last 3 vr commodores do the exact same thing!
    I NOTICE HOLDEN DESIGNED ITS BADGE ROUND DUE TO CIRCLES GO ON FOR EVER..
    vx s pack II
    Jan 2010
    aLKIDA
    Check for codes bridge pins 5&6 under dash.
    Could be Key,Bcm,Inhibitor switch,starter relay,starter.
    Could be a security link failure between key and bcm. If so this should come up on the error codes.
    VE series2 E3 HSV Clubby & VS Calais 5.0L
    Mar 2010
    Around WA
    Disconnect the fuel pump sender & replace the fuel pump fuse if it has blown under the bonnet.
    It may then crank and your fuel pump would be at fault.
  1. 1996 vs commodore v6 will not start
    By st3ev in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2010, 02:21 PM
  2. vn commodore wont start
    By STYALR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2010, 07:28 PM
  3. vt ss commodore wont start
    By steve67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-09-2009, 08:26 PM
  4. commodore wont start
    By marlon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-11-2007, 05:16 PM
  5. vs commodore help..wont start
    By 21AZE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-07-2006, 11:08 PM
