Results 1 to 18 of 18
Thread: VS Caprice electric seats
    VZ Calais
    Aug 2005
    Mackay Qld
    Default VS Caprice electric seats
    G'day all,
    Can someone tell me how to set the memory on my seats.
    The car is fitted with 8 way electric seats. When the car is switched off, the pass/side seat goes back to a stupid position.
    Cheers, Col.
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    i dont think the passenger side has the memory option, only drivers side.
    dont worry, il start a ride thread soon.
    VZ Calais
    Aug 2005
    Mackay Qld
    How do i operate the seat memory?
    Where can i buy new plastic bits for the seat sides?
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Not sure what the buttons look like on a VS but with a WH you put the seat in the position you want and then press and hold one of the three memory buttons until you hear a tone.
    Wreckers or Holden for the parts you mentioned.
    MY RIDE
    VZ Calais
    Aug 2005
    Mackay Qld
    VZ Calais
    Aug 2005
    Mackay Qld
    I just rang the local holden dealer. The seat plastics are NLA......since 2004.
    VZ Calais
    Aug 2005
    Mackay Qld
    Hmmmm.....i turned on the ignit......pressed memo 1......seat seems to be staying in the right position.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    yes you are right, the passager seat does not have memory. ONLY the driver seat. And those plastic bit comes out in 2 colours one light grey the other light blue. I've got a set of light grey in good condition. As to getting the memory to work. 1 get into the postion you want 2 depress and hold memo (memory) button 3 press button 1 while and memo button is held 4 the red light on the switches is designed to warn you that you are altering the memory 5 release both buttons
    NEVER LATE IN A 355ci
    VZ Calais
    Aug 2005
    Mackay Qld
    That's the info i was looking for. Thankyou.
    It would have been easier if i had an owners manual when i bought the car. LOL
    I know the car has a heap more features than i ever use. [or know of].
    I've never played with the dash/trip/over speed ect since i bought it.
    pjdm1980's Avatar
    pjdm1980 is online now The Holden Hunter!
    Feb 2009
    Geelong, Victoria
    Could you use a standard commodore seat plastic and modify it?
    VZ Calais
    Aug 2005
    Mackay Qld
    I'm not sure m8.
    I think, because the electric seats have 'windows' cut out for the switches, if you tried to make them fit it would end in disaster.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    So you couldn't just cut out the holes?
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    VZ Calais
    Aug 2005
    Mackay Qld
    Cutting out the holes wouldn't be too much of a problem.
    It's the 2-3mm bit between the holes that i think would be a problem.
  15. #15
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    All i can say is give it go, probably save yourself some bucks!
    Can't hurt.
  16. #16
    VZ Calais
    Aug 2005
    Mackay Qld
    I tried making a new scratch plate for my brothers guitar once. It was supposed to be a x-mas pressy for him.
    It was $50 for the material. I marked it all out....cut it to shape....bevelled it...then while i was drilling the last hole for the pickup, the whole thing ended up in 100 pieces! lol
    I haven't forgotten that lesson. I rekon cutting the holes in the seat sides would end up the same.
  17. #17
    Oct 2005
    mate they are complete diffenent commodores to caprice, even if it fits it wouldn't even look right
  18. #18
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    the plastic bit are anoyingly fragile,i have a almost full seat of caprice seats(currently hunting down wiring for drivers seat and memory switch) and they break piss easy,not sure if i should find better ones in the same colour(i have 2 different coloured bits) or clue and paint what i have.
    WTB:VR/S HSV 250km/h speedo cluster
  1. caprice electric seat loom
    By NEDWOB in forum Electrical Wiring / Questions
    Last Post: 13-08-2009, 12:53 PM
  2. Caprice electric seat motor
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2009, 11:42 AM
  3. VS Caprice electric seats diagram
    By shanhsv in forum Electrical Wiring / Questions
    Last Post: 20-05-2009, 06:29 PM
  4. VS Caprice electric seats question
    Last Post: 20-05-2009, 11:41 AM
  5. need pics of VS Caprice seats mounts - any one witha caprice
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2006, 05:43 PM
