Results 1 to 5 of 5
Thread: Vt/Vy auto in VS
    VN SV150
    Jul 2005
    victoria
    Default Vt/Vy auto in VS
    Guys i have searched threads in regards to installing a vt/vy auto in a 1995 vs ecotec but have found alot of conflicting feedback.
    My question is can it be done ? Has antone recently installed one?
    My tranny is slipping alot and was hoping to upgrade to a newer box?
    I have found a few low kilometre autos from a vy ecotec and have found them to be cheaper than the vs box.
    This is a picture of the auto
    Attached Thumbnails Attached Thumbnails Vt/Vy auto in VS-byusekbgkkgrhgookkiejllmukorbkg3e6uodg_12.jpg
    White Tiger's Avatar
    White Tiger is offline Semper Fidelis
    VN Executive Wagon VR Berlina V6
    Jul 2009
    Bordertown SA
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    Yeah i have install a few of those auto in. They bolt up the same, as a normal 5hdd or 6hdd out of a vs, but you have to slice and dice, a bit of the gearbox so the exhuast can go through (right hand side) and the inspect cover doesn't fit on too as they are both diffenece. Also not having a inspect cover is a R.W.C problem and a risk of something getting stuck in between the ring gear and convertor. But other, than that they are alot better box, firmer shifts and can take a bit more power
    NEVER LATE IN A 355ci
    VN SV150
    Jul 2005
    victoria
    Quote Originally Posted by BT1-355 View Post
    thats good to hear,does the loom all plug in ok?Will the ecu work with the box?
    Also which converter did you use? vs or vt one with the vt / vy box?
    vr with ecotec
    May 2009
    i there did this to my vr ute put a vs engine and box in then box shit its self so i went for a vy bos only cost me $275 compaired to $600 for a vs one. Like you may have read they bolt up the same way. All the wiring should be the same if you have a vs already. You need to cut the box before you put it in the top mount on the box and for the exhaust if you have the dust cover then it will fit straight back on once box is in youll just need to cut the edge for the exhaust.
  1. vr vs auto
    By gcas in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 10:22 PM
  2. Changine from Column Auto to Floor Auto
    By VNCPTR in forum General Discussion
    Last Post: 16-04-2009, 01:48 AM
  3. 03 vy auto same as 04 auto trans?
    By victtor in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-09-2008, 05:20 PM
  4. Fuel Mileage Holden VZ Wagon(auto) Vs Subaru 2.5(auto)
    By phantomwalker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-06-2008, 06:38 PM
  5. want to swap a new not reco VS 5L auto for a VN 5L auto
    By troy7979 in forum Swap / Wanted to Buy / Trade
    Last Post: 26-08-2005, 12:01 AM
