i did the paper clip trick and only got 12 no other codes so still dont get why its still stalling.
i have changed the cas
wat should i try next ?????
Clean your iac motor, and check if it has pop out. If it has then, i would change it with a NEW GENUINE one. oh yeah check your base idle, if that is out, then that can also cuz it to stall
NEVER LATE IN A 355ci
