Results 1 to 5 of 5
Thread: 96 VS starting issues
    VS Executive
    Sep 2009
    Default 96 VS starting issues
    Hi there.
    New to the forum and urgently need help please.
    My commodore only starts when it wants to. When I turn the key, the lights come on but nothing happens, no noise nothing. Then I try it again while pumping fuel, and only after several tries it starts.
    Any clues to what this might be?
    Thanks!
    VS executive
    Jun 2009
    dont pump the pedal its fuel injected, just turn the key too the accessories on and wait a second before trying too crank.
    could also be a dying battery in your remote
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try moving the T bar from P to N and try starting there - it could be the inhibiter switch. Also make sure the red flashing immobiliser light below the wireless goes out when the ignition is on - if still flashing the car will not start as the light flashes when immobiliser is on.
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Quote Originally Posted by hako View Post
    What hako said . A loose/bad battery terminal can also stop it from cranking, try giving them a wriggle to see if they are loose. Also take them off and give it all a go over with wire brush.
  1. Starting Issues
    By I P Freely in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 04:26 PM
  2. vp v6 starting issues.
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2008, 04:35 PM
  3. Vn Ss Starting Issues
    By Jazack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2007, 10:12 PM
  4. Starting Issues
    By fennski1_au in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-12-2005, 07:36 AM
  5. VP Starting Issues!!
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2005, 12:08 PM
