Results 1 to 13 of 13
Thread: changing irs diff oil?.....
    vr calais 5ltr
    Aug 2009
    nsw
    Default changing irs diff oil?.....
    i was going to change the diff oil when i did the cv boot yesterday not realizing it was going to be the way it is. anyway the only way i can see of doing it is to actually remove the hole center. problem i have is i have no one to help me plus i have never worked with irs before.
    personally i don't see why they put irs in them its a pain. lowering need camber kit plus more things that can go wrong i.e the cv joints and the boots plus all the extra bushes when they need to be replaced.
    anyway i'm moving off my own topic haha could someone tell me what way i'm spose to go about changing it also why the hell is the oil so dear cost me 59 dollars for 2ltrs....
    My Ride:
    vr calais 5ltr (gone to the darkside)
    Previous rides:
    zj fairlane 351c, nf2 fairlane 302w, ef fairmont str8 6, ef2 falcon str8 6, ef fairmont ghia str8 6
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Fairly sure the bottom middle bolt is the drain plug?
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    vr calais 5ltr
    Aug 2009
    nsw
    if that is the case i may do it that way but also i was hoping to open her up and have look to see if it is buggered or not because it does single leggers and has lsd high performance diff (according to tag)
    My Ride:
    Previous rides:
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    are you sure it has lsd stamped on it and not just high performance diff??
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    vr calais 5ltr
    Aug 2009
    nsw
    yes it says "lsd
    high performance"
    exactly like that. BUT it is only a tag it is easy to change but why someone would i don't know. only way to tell really is to open it up and have a look at its insides. i also heard all commodores with irs have lsd's its probably been said before but i thought mayswell ask since i already wrote it lol
    My Ride:
    Previous rides:
    ryno_vrx's Avatar
    Nov 2008
    Mirani
    Quote Originally Posted by vrcalais5ltr View Post
    would be nice but i dont think so
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    LSD is not standard with IRS. I wish it was.
    The bottom bolt is the drain plug as said above. As for oil you got ripped off , it only costs about $20 to refill your diff.
    vr calais 5ltr
    Aug 2009
    nsw
    thats good to know i'll take it back tomorrow thanks i was going to pull the hole center out didn't want to do that much work though especially not by myself lol trying to hold the center up while undoing the last few bolts might be bit dangerous haha
    My Ride:
    Previous rides:
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Quote Originally Posted by greenacc View Post
    Not true. You need gear oil with special additives for an LSD differential. Castrol SAF-XA costs $29 a litre at Repco and slightly more at other places. You need 1.7 litres and it's only available in one litre bottles.
    Because of the limited space it's very difficult to fill the differential without a proper pump. I use a Macnaught suction pump which holds 500mls and is easy to use with a long tube nozzle. I think it was around $40-50 at Bursons. You can use it for a variety of other things.
    greenacc's Avatar
    VE Berlina
    Jul 2008
    OK OK thats true, it all depends on if the diff is LSD or not, i was talking about price of oil for a standard centre - i use castrol LSX90 for mine ( not LSD ). Isn't there a test you can do to check if its LSD or not ? jack up the rear wheels and turn one wheel and watch the other ? can't remember what to look for but its something like that.
    As for filling I use a 1 litre bottle with long spout, hold it up near the sway bar and squeeze it in the fill hole.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    vr calais 5ltr
    Aug 2009
    nsw
    Quote Originally Posted by BlackVXGTS View Post
    well i got mine from repco so the price wasn't wrong lol its 29.49 now lol as for it being lsd i'm not sure wether the test of jacking it up and seeing if both wheels spin would work on mine because i think the center is buggered
    My Ride:
    Previous rides:
    ryno_vrx's Avatar
    Nov 2008
    Mirani
    Isn't there a test you can do to check if its LSD or not ?.
    yes, it involves one foot hard on the accerator and the other on the brake
  1. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  2. changing a vn diff
    By milkandjuicecomein2litres in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2009, 03:25 AM
  3. changing diff oil
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-10-2007, 01:59 PM
  4. changing diff
    By meanrooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:52 PM
  5. changing diff oil on VS, how much?
    By pHiLix in forum General
    Last Post: 31-05-2005, 07:57 AM
