hi all am having some trouble getting a straight answer from the car mobs so thought someone else may have tried i have a v6 ecotec and a v8 t5 from a vs need to know if can be addapted to suit each other. any help would b much appreciated cheers
The input shafts will most likely be different lengths. Plus the gear ratios will probably be different. If your going for a conversion, you got all the other bits?
