Results 1 to 18 of 18
Thread: fan blowing to feet and screen only
    VS Commodore
    Sep 2009
    Default fan blowing to feet and screen only
    Hi,
    I have got a VS exec and it only blows air to the screen and feet.
    Have tested with another fan selector, no fix still same problem.
    Works on all speeds.
    Any ideas??
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    VT V8 Calais
    Mar 2007
    Spot on, under the glovebox in the dash would be my first thing to check.
    There is a small block with some vacuum hoses running to it.
    Turn the car on with the aircon on and find the block, feel the hoses for air leaks, if there is one try and push the hose on again.
    I get the feeling I may have to replace the block in my VT because under medium to hard acceleration the aircon goes to the windscreen only
    Good Luck
    50LTRv8
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The VS exec doesn't have the block like the VT - the usual cause of this problem is that a vacuum hose has been dislodged usually from the heater tap vacuum switch which is located to the left of where the clutch pedal would be....about 100mm above where your left ankle is when in the drivers seat. I've attached a pix to show to 2 vacuum lines - they have the clear plastic plug ends. If either is dislodged you will have no vent control. Ask me how I know!.
    Attached Thumbnails Attached Thumbnails fan blowing to feet and screen only-heater-vacuum.jpg
    VS Commodore
    Sep 2009
    Thanks for that info Hako but I have checked this, it is the most obvious and easiest place to look all was intact. Any other ideas where I can look?
    VP Exec
    Jun 2005
    It's a common fault so you should get something from a search too. One of the more obscure ones is the one one-way valve - white plastic, in line with the vac hose to the manifold in the engine bay - can leak. Kinked, cracked or dislodged vac hose, leaking vac ball under the LH guard.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The mode selector - the switch that changes the vacuum path to direct vacuum to different slaves - this selector switch can break internally - what happens is that a plastic clip which hold the selector switch together breaks and this allows the switch to leak vacuum - there is a fix in the aircon thread and this is a post by "joe rolls commo":
    Hey, I'm having the same problem with my A/C vents as other previous posts have pointed out. The problem being that I'm not getting any air-flow from the centre-face vents, d/s p/s door handle vents, or the rear passenger vents. Air is only flowing into the foot-bays & windscreen de-mister.
    -I'm getting error-code #36. I thought this was inlet-manifold gasket - but nooooo.
    -With the car idling, A/C on, I'm getting a hiss on 3 of the 5 positions (feet, face & full circulation) on the selector switch.
    -I've pulled out the glove-box, centre-console etc and traced back all the lines, only to find they're all in position & un-damaged.
    -I've traced the lines from the vacc'-tank, to inlet manifold, into the fire wall, doing the CRC test - again, all connected, no damage.
    -The connection to the selector switch is complete, no probs there.
    -I'm getting an air leak down where the metal coolant-pipes feed into the heater core.
    I've sifted through all the A/C threads & still can't figure a solution. I'm thinking of getting a new 'air selector unit' & dropping it off to a pro if that doesn't work. In any case, I'll post the solution when I sort it.
    Until then, anyone got any ideas?
    ***EDIT
    I found the problem. The switch was knackered (knew it would be something simple). I don't have a camera handy so I can't put up the pictures, but I'll try & explain.
    When you pull the vent-selector switch out, it breaks up into five parts:
    -The male plug that the vacc' hoses connect to.
    -A coin sized washer, with a rubber 'maze' on one side.
    -A back-plate
    -A spring.
    -And a push clip that holds the lot together.
    Cause: After I pulled the switch out I noticed that it wasn't hanging together properly. Long story short, the little plastic push-clip (like all plastic bits in a VR/VS), that hols the switch together was broken. One of the pins was snapped off on the push-clip, combined with the spiring putting pressure on the switches assembly, causing the washer with the rubber "maze" to sit skewiff.
    Solution: In aussie fashion, I picked up a twig, carved it into a wedge, re-assembled the switch and jammed the peg in push-pin, which opened it up & held the switch together. So the problem was fixed for the price of a ... twig (it's now a GM twig). Alternatively, holden wanted $160 for a whole air-con console, and local air-con bloke wanted $90 check it out. Didn't get round to checkin with a wrecker.
    Notch one up to me being a ****in legend!
    VS Commodore
    Sep 2009
    VS Commodore
    Sep 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by xb1977 View Post
    Thanks for the post Hako, what switch are you refering to?
    The switch is the one you turn to direct air to demist/face/feet etc. They do fail.
    VS Commodore
    Sep 2009
    VS Commodore
    Sep 2009
    dynoryder is offline Banned
    vp executive wagon
    Oct 2009
    A.C.T.
    i stuffed my vac system moding my aif filter box
    there is a big black sphere under the air box in the wheel arch i drilled into it
    had to slag it up and it works fine
    VS Commodore
    Sep 2009
    VS Commodore
    Sep 2009
    VS Commodore
    Sep 2009
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    have you checked all the vacuum points from heater tap to the vac ball?
    and 3 Dangerous non ABS VN's
  18. #18
    VS
    Mar 2008
    Default Success Air con blowers working
    --- Relates to VS Commodore----
    I removed the air con control from dashboard then removed the vacuum control selector from the housing. In order to get to one of the screw you need to remove one of the electrical connectors. This is done by levering the connector out as there is a small lug which locks it into the housing. The control is held in with two phillips head screws.
    THen using thin nose pliers and screwdriver I carefully disassembled the switch. there is a rubber 'gasket' which has channels moulded into it for the vacuum to work, I noted that there was some dirt but also what apeared to be oil/lubricant ?? Perhaps this was blocking the channels even though there wasnt that much and I am not sure if that should be there. Anyway I cleaned it and reassembled matching the gasket and the metal plate replacing the spring then holding the cover in place pushing hard enough for the clips to go over the plate (note the plate only aligns with the cover one way) then whilst holding inplace, I replaced the plastic locking clip and twisted it into position.
    When re-inserting the switch it will only go in one way as the two lugs are different sizes. Replace the two screws and reinsert the electrical connector.
    After all that it worked straight away, so success for now, will see how long it lasts.
  1. Black screen after bios screen
    By TVR-190 in forum The LAN Lounge
    Last Post: 26-05-2009, 12:10 PM
  2. Hot Feet??
    By Milky2106 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2008, 06:51 PM
  3. Replies: 3
    Last Post: 13-10-2007, 01:52 PM
  4. Hot Feet
    By hardlyevolved in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-01-2007, 07:09 PM
  5. laptop screen into dvd screen?
    By tweakt in forum Electrical Wiring / Questions
    Last Post: 10-06-2005, 09:48 AM
