Results 1 to 5 of 5
Thread: VS Starting Problem
    VS Ute Series 2
    Aug 2009
    Wagga Wagga
    Default VS Starting Problem
    Hey, My ute will sometimes struggle to start. This includes hopping in, turning the key all the way and nothing. I take the key out and press lock then unlock try again and it will start. Or when i turn it off and leave the keys in and try and start and get nothing. Take it out lock and unlock and it works.
    Is this a lose cable in the igintion barrel or security feature i have no idea about?
    Reece
    vs wagon
    Jan 2009
    darwin
    more than likely a dry joint or faulty relay inside the body control module.
    Brett is offline Legend
    VR V8 Ute
    Jun 2003
    Gladstone, QLD
    The last 3 things you mentioned are apart of the security system, its described in your glove box owners manual.
    But im unsure about the "hopping in, turning the key all the way and nothing".
    Damo304's Avatar
    Damo304 is offline Donating Member
    VT SS 5 LITRE
    Apr 2009
    Perth, WA
    could be a few things
    - a bad earth, check that your battery terminals are secure and clean
    - the most likely culprit will be your key which you will have to go to holden and get a new one programmed.
    VS Ute Series 2
    Aug 2009
    Wagga Wagga
    when i said nothing happens i meant that as you turn the key through the multiple stages lights come on then when u get to the igintion or last stage all power gets cut.
    well i got told that it may be an immobiliser, but the key idea sounds pretty good aswell because mine is in shit condition
  1. VN Starting problem AGAIN!
    By VN Lukey in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-07-2009, 10:05 AM
  2. Vt Starting problem
    By bubz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-05-2007, 10:22 PM
  3. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  4. VN starting problem
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2006, 10:21 AM
  5. VR BT1 V8 Starting Problem
    By vrbt1ss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-05-2005, 11:37 PM
