Results 1 to 15 of 15
Thread: Idelinng Extremelly rough
    vn commodore s pac
    Apr 2005
    Default Idelinng Extremelly rough
    Hey guys have a problem with my vs ecotec.. was driving down road one day and pulled up at lights,when i went to pull off from lights car was running shocking and i cant get it above 40/50 kmh i have replaced all my leads/plugs and have tried swapping over Crank angle sensor, AFM i was goin to try the 02 sensors next but most people say that if it o2 sensor it gets better as it warms up, but mine is just stuffed all the time... im totally stuck for ideas...any help would be apprecitated
    4.2 turbo vs ute
    Feb 2009
    hills district sydney
    try the module under the coil packs. mine needed a new one of those. and check the wires coming out of it and aroud your belts ect
    vn commodore s pac
    Apr 2005
    im getting spark to all leads... could the module still be the problem or would that make me not get spark???
    vn commodore s pac
    Apr 2005
    BrAdAsS is offline Banned
    VX Executive A4
    Dec 2005
    Brisbane Northside
    I just replaced my Coolant Temperature Sensor $80 from repco... Im not saying that's what is wrong but it made my vx idle better and has improved my fuel economy and pepped the car up off idle. It also removed a problem I had where the revs would not sit at 1000-1300rpm it would jump and clear from 1000 to 1300rpm as a normal rev progression. It also seems to not suffer from hot weather as much either.
    I got told by the injector service guy that the coolant temp sensor influences injector timing which is why Im noticing a difference.
    Have you checked for fault codes? If you search on here you will find which pins in the VS ALDL to short for finding fault codes manually.
    vn commodore s pac
    Apr 2005
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    id replace both ur o2's anyway man, also check battery, maybe give throttle the body a good clean out too
    Check ur codes too man and see what it comes up with
    Just Commodores - For All Your Holden Commodore Needs
    and this thread may help even tho its for vr/vs
    Checking error codes VR/VS (Revised)
    good luck mate
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VX Executive A4
    Dec 2005
    Brisbane Northside
    Test for fault codes. This will hopefully give you something to go from instead of replacing things blind and hoping for a fix
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    vn commodore s pac
    Apr 2005
    i have a haltech interceptor but am having trouble finding a laptop old enough to have a serial port so i can connect it up
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    When you say it's running shocking do you mean it's missing or just is 'weak'?
    The reason I say this is because it may be a transmission problem - you may be in Limp Home Mode which will make it seem like it's driven by an elastic band.
    vn commodore s pac
    Apr 2005
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    There is a small rubber hose on the underside of the throttlebody. Take your engine cover off and check to make sure that it has not come off.
    vn commodore s pac
    Apr 2005
    hey mate i got a YT SC so no need to take off engiine cover... but already checked all vacuum lines ect.. and all are intact and connected
  15. #15
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    check the fuel pressure reg vacuam hose and make sure its not leaking fuel direct into the inlet failing that ide be starting to look at the interceptor
  1. Rough idle, Rough take off and rough stop.
    By Niggadore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 05:49 PM
  2. Vn - Rough start & Rough Running Below 2k
    By ghog1726 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2009, 10:02 PM
  3. Very Rough VK
    By RayRay07 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-10-2008, 03:10 PM
  4. Rough VK Value?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-10-2005, 04:13 PM
  5. rough...
    By rattattack1313 in forum The Pub
    Last Post: 26-02-2005, 06:44 PM
