Results 1 to 18 of 18
Thread: can broken engine mounts set of the knock sensor?
    vs calais
    Dec 2008
    Default vs calais v6 sluggish/holding back until 2500rpm, why??
    hello everyone
    lately ive been getting a rather odd hesitation/sluggish feel when i take off hard off the lights... it feels as if somethings holding it back for a few seconds until it reaches around 2500-3000rpm then it all of a sudden takes off
    i checked leads, spark plugs, fuel filter, cleaned throttle and plenum, air filter, but still nothin has helped
    then i noticed the other day my engine mount has broken on the left side causing the engine to move alot on take off
    could this be setting of the knock sensor and causing the hesitation??
    what else could be causing this?
    its very annoying as the car feels alot down on power, then gets a surge of power of a sudden after 2500-3000rpm
    btw the car is a vs calais series 2 v6
    VR Berlina S2
    Aug 2009
    knock sensors go off when they sense the engine is detonating.
    selling vp calais wheels with 97% rubber hardly used!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can simulate it by hitting the block or head with a hammer (this is not a joke). Do a search on it as testing the sensors involves doing this ........I'd check first exactly where to hit with the hammer. I'd imagine that the knock from the engine mounts would only affect the car for a split second as the ECU reacts instantly.
    VP Executive R-spec
    Jan 2005
    Even the loose rocker setup from a solid cam can make the go off so for sure a busted mount can
    VR Berlina S2
    Aug 2009
    well then i'd say yes, because if the engine moves, i'm sure it would simulate a knock
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    I'd be surprised if it did. I would imagine that the vibrational frequency caused by a broken engine mount is much lower than that caused by pinging. If a broken engine mount could cause the problem, then wouldn't bumps in the road etc...etc set them off?
    As Hako said, you use a hammer to test them - this is going to be high frequency vibration in the block.
    vs calais
    Dec 2008
    will try and check the hammer way if same sorta thing happens
    on the other note,
    what could be causing hesitation up till 2500-3000rpm, then all of a sudden it takes off??
    its like as if something is holding the car back
    just thought the broken engine mount might have something to do with it
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    could be just a dodgy lead or plug.
    Reaper
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its broken and the engine is banging the exhaust against the body or hitting the k frame can set them off easy as
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    i thought the knock sensor olny went off when the engine was pinging? but i can understand if the engine mount is that loose that the engine can move and trick the sensor... try the old hammer trick
    if youv checked fuel and ignition then try checking the trans...
    vs calais
    Dec 2008
    Default ...
    Quote Originally Posted by chrisdoesitbetter View Post
    ive checked fuel wise, and checked coils leads and plugs
    what could be with the trans? i know its not slipping...
    vs calais
    Dec 2008
    vs calais
    Dec 2008
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    many things can effect the ecotec. dodgy TPS. leaking or blocked injectors and tired/stuffed O2 sensors.
    have you tried cleaning the MAF?
    the only things i haven't changed on my ecotec is the CAS and cam angle sensor, everything else is new and she goes like a rocket now.
    does your car use coolant?
    Body by Holden, Soul by Brock
    the Legend will live forever
  15. #15
    vs calais
    Dec 2008
    any other ideas? could anything be wrong with the gearbox, i know its not slipping, but could it be anything else
  16. #16
    Apr 2006
    Auckland NZ
    the best way to diagnose is with a ALDL cable and efilive or scannerpro type diagnostic software.
    this way you can see exactly which sensor is playing up. otherwise you have to go through a process of elimination with usually means replacing parts untill you find the culprit.
    personally i'd start with the O2 sensors if the car has more then 150,000km's on it and the original O2 sensors are still fitted. having said that, there is a common factory fault with the O2 wiring (4wire O2, VS models only) and you really need to check it with diagnostic software to ensure proper fuction otherwise your new O2 sensors could be stuffed in a couple weeks
  17. #17
    vs calais
    Dec 2008
    Default re
    Quote Originally Posted by immortality View Post
    how do i go about getting one of those aldl cables and the software, best and cheapest way??
  18. #18
    Apr 2006
    Auckland NZ
    software is free t odownload for trial. you can make your own cable if your electronically inclined or you can buy one. you see em on ebay sometimes or try delcowizzid.
  1. Broken Engine Mounts???
    By younglion in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2007, 09:09 PM
  2. Knock sensor location for V8 engine.
    By broderikb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2007, 10:10 PM
  3. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  4. my knock sensor was broken for abit what does the car loose without it?
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-11-2005, 10:08 PM
  5. knock sensor engine code
    By superchargedv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2005, 06:38 PM
