Results 1 to 9 of 9
Thread: VS Immobiliser
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Default VS Immobiliser
    Hey guys, searched a bit but didnt find a definitive answer.
    My keys been stuffing me around a bit, firstly central locking wasn't working, opened the key up to find the battery not clipped in (If you know what I mean lol) so clipped it in, works fine now.. even chucked a dab of superglue under it to hold it on.. But the immobliser (Pretty sure) problem has always happened and still is now.. I turn the key, wait a few seconds on ACC then turn it and it doesn't crank, with the immo. light still flashing.. So I just sit and keep putting key in and out and turning until it starts.. Sometimes been sitting doing this for about 15 mins..
    Can anyone tell me what I should get looked at? The key or an immobliser component? I was thinking of maybe cleaning the immobliser contact part on the key and barrel would that help?
    Any other help appreciated..
    Max
    VS Berlina 3.8
    Dec 2008
    Are the two pieces of metal around the barrel making proper contact with the key? You might just have to bend them up slightly.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also try pressing the unlock button on the key after it is in the ignition keyhole (before you turn to start). This usually makes it work quicker although it is no permanent fix. Mine has done this every now and then for the last 6 years.
    '97 VS Commodore + '98 E36
    Apr 2005
    Damo304's Avatar
    Damo304 is offline Donating Member
    VT SS 5 LITRE
    Apr 2009
    Perth, WA
    Sounds like your due for a new key!!!! If you have a spare try it and see if it makes a difference, that should give you some idea where the problem is.
    2005 VZ SV6
    Jun 2009
    Hey guys, yeah the metal is contacting.. Don't have a spare, only came with one.. after lots of looking like an idiot sitting in my car for 15 mins on the way to and from QLD, I have reached the conclusion that to start it i need to lock and unlock it using the key buttons... Seems to work every time now.. Is this normal lol?
    1994VR
    Jan 2011
    Queensland
    Default 1994 vr
    Hello, im new to this site and this car
    I bought a $1000 special that really isent too bad just needs love and RWC
    Have had an awesome day trying to get working keys for the thing mine are totaly rooted
    I have looked about a little bit on bypassing the immobillser and have come to the conclusion
    that there probedly is a way but your unlikily to get it out of commodore owners, from what
    has been said to me from machanics is that it controls other stuff aswell. I used to start my
    magna with a screw driver, that immobillser was disabeled on the side of the road in under
    30 seconds by RACQ, so this perplexes me.
    Also are you able to leave the keys in and Acc on for awhile and it will start?
    someone also told me they got new keys from MR Mint type key shop you would find at the
    shops and the car learns the new key, was a VS tho. I have another lock smith telling me to goto
    Holden then he can do the key, cause mines dead.
    I would like to just get rid of the immobillser and be done with it, save some cash and not have
    to carry around the huge key thing, just the key itself.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by 1000Dollaspecial View Post
    You can bypass the immobiliser by leaving the ignition key in the ON position for 45 minutes.The red LED immobiliser light will stop flashing once its bypassed,it will then start.But once its turned off again,you will need to wait another 45 minutes before it will start again.Its basically a safety backup so you can start it and drive it to get it fixed.Mr minit and similar places need a working ignition key so they can copy it,or the security code specific to your vehicle.Holden can access this security code with your VIN,they then use this security code to program new keys with a tech 1 scantool.Most holden dealers charge a fair bit for this service, but if your current ignition key is completely f****d,then you dont have much choice really.
    1994VR
    Jan 2011
    Queensland
    Thanks for the infomation at least i can tell the machanic that now, he said that wasent true. if i dont get new keys to him by tomorrow arv. I hope holden doent charge me to get the number code but probedly will.
    Its classic, waiting 45 minutes after u turned the car off was a similer experence in my old car everytime so i would be more than used to it.
  1. vs immobiliser
    By canb_vn06 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2012, 11:08 AM
  2. Vr/vs Immobiliser??
    By Bob129 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2009, 11:22 AM
  3. Immobiliser
    By davebart25 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2006, 10:19 AM
  4. vs immobiliser?
    By danny1987 in forum Electrical Wiring / Questions
    Last Post: 06-10-2005, 06:54 PM
  5. immobiliser
    By ducatis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 05:38 PM
Tags for this Thread
