Water has probably been pooling up in the spare wheel well, in the boot, for years. I've owned the car for under a month, and only made the discovery yesterday.
Removing the spare wheel reveals a rust hole of enormous proportions. The ground below can clearly be seen. Its only a matter or time, it seems, before the entire wheel falls out.
I've taken the wheel out to allow the area to dry out while I figure out what to do next.
I'm wondering what people's suggestions are for fixing this problem. Cut away the rust and weld on a new sheet of metal? If that's the case, then it looks like I'll have to cut away quite a bit. Might not have much of a floor left afterward.
Suggestions are highly appreciated.
Regards
I'm not sure about commodores but i know of a person who had the same problem with his evo and he got anoher one cut another wheel well out of another car and weld into his.
you obviously have water leaking into your boot probably from your back /quarter windows so you might have to address that first but I would get another bottom section from a wreck and weld it in but leave the bottom hole open so water can get out if it gets in and cover any bare metal with anti rust coating .Mine had the start of some rust so I fixed that and took out the quarter windows and sealed them with windscreen sealer and then covered eveything metal in fisholene and after it was fixed I left the hole open in the bottom...no dramas since
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
I just shapped up a bit of galve sheeting and with a bit of Selley's all clear stuck it over the top of the large hole and fixed it in place once set with a few pop rivits. I treated the rusty bits with rust kill first. Painted it all in a heavy coat of black paint and put the spare back into place. Cant see it any more
And also re-sealed the rear qtr windows as well.
and 3 Dangerous non ABS VN's
Thanks for the help guys. Gives me some ideas on how to approach the issue. I found the thread on the how to fix the leaky quarter window. Good write-up that is.
I have that same bloody problem, what a pain in the arse. I had a leak in the tail light covers and the water overflowed into the wheel well. The result, a one inch sized hole which could get worse. It was recommended that i cut out the rust, rust kill, then bog and paint. Gotta get off my arse before it gets worse.
http://tinyurl.com/MetalisAwesome
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
Once you have properly treated the rust, couldn't you just fibreglass it up? or is that a bit dodgy? I mean it's not exactly a structual point.
A fibreglass repair kit would be better than nothing, but how would it hold up in the long run? Anyone tried this before?
Albert Einstein
very common problem throughout the v series commodores .if you have access to a welder it only takes a short time to weld in a patch .............unless it has been let go to long
I have fixed 3 of them so far for people and have another one i have to do soon
Cut out the spare wheel well, Get some road side assist care, Whack a rear mount turbo in
Problem solved ^_^
Originally Posted by garth
I had this problem in my VN, the wheel area was full of water for at least 10 years! never rusted tho. So it must take along time to rust, unless your car didn't have so much paint on it from the factory. Still it will be easy to weld a new section in. I bet holden still sell that peice?!!
Just done a search and found this thread.. Mine is getting worse so been thinking of going to the wreckers and cutting it out and grinding the old bits of rust out, kill rust it and pop rivit the new bit in.. Seal it up and paint it.. Should be a easy fix
