Results 1 to 14 of 14
Thread: -- ABS Light on! Help ! --
    1994 VR SS
    Sep 2009
    Default -- ABS Light on! Help ! --
    My ABS light on. I have a VR SS
    5.0L. I've Checked both fuses under the bonnet and also the brake fluid levels. Any other advice would be very welcome. cheers
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    has it been on since you owned the car?
    whats the difference between my missus and my blower??
    well they both whine but the blower actually puts out
    1994 VR SS
    Sep 2009
    Quote Originally Posted by ryno_vrx View Post
    Yes , but i've only owned it for two days.
    ryno_vrx's Avatar
    Nov 2008
    Mirani
    there's a chance the previous owner may have changed your diff and the new diff may not have the abs gear sensor thingys that sit on the sides of the diff .......not sure how to explain it i'll try to find a pic
    ok i was trying to explain the thing circled in red. and the bit circled in yellow is the sensor from what i can tell
    1994 VR SS
    Sep 2009
    ryno_vrx's Avatar
    Nov 2008
    Mirani
    you should be able to see a pic... also disregard the black arrows on the image they mean nothing
    1994 VR SS
    Sep 2009
    Thank you sir. I was using the wrong browser. I will check this in the morn. ta
    ryno_vrx's Avatar
    Nov 2008
    Mirani
    lol SIR now i feel all important.....and old
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    He may have a solid rear which will be different to the one from sir ryno_vrx.
    First check would be to remove the main battery terminal for 30 seconds to (possibly) reset the fault light. If that doesn't fix it then check the ABS connectors where they meet the hubs as it's not uncommon for them to get knocked off or damaged.
    1994 VR SS
    Sep 2009
    ryno_vrx's Avatar
    Nov 2008
    Mirani
    thought all vr ss had IRS???
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    is the abs light the only light on? cause when my voltage regulator on my alternator went it sent a battery warning and a abs off warning...
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    VS Clubby
    Jul 2009
    Sunshine Coast
    Thanks for that PDF
  1. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  2. vr calais head light and interoir light brake problem
    By lestat2220 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 01:38 PM
  3. Berlina/Calais/Statesman Roof Inteior light into basic model with standard light
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2008, 10:07 PM
  4. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  5. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
