Results 1 to 11 of 11
Thread: vs clubby issue
    vs clubsport
    Aug 2008
    Default vs clubby issue
    hey guys just wondering how can u tell if a 02 sensor is ***t
    also on the vs 5.0l is it 2 wire or 4 wire on the 02 sensor
    thanks
    Damo304's Avatar
    Damo304 is offline Donating Member
    VT SS 5 LITRE
    Apr 2009
    Perth, WA
    it will run a bit rough and will more than likely make the engine run rich on fuel, not sure how many wires the 5l are
    94 VR Statesman
    Aug 2006
    vr-vs series2 are 2 wire s3 vs -vt are 4 wire also vr-vt 355 factory motors are 4 wire
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    you will be using excess fuel too
    Reaper
    vs clubsport
    Aug 2008
    VrWagz1's Avatar
    May 2008
    wollongong
    i would think so, but how noticable it is i dont know.
    Reaper
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    you will use noticably more fuel, idle will be rougher and it should set a trouble code so check your diagnostic...
    vs clubsport
    Aug 2008
    its got a aftermarket ecu i noticed today when i drove the car home from work my 02 sensor was slightly white??
    vs clubsport
    Aug 2008
    Vp series 2
    Jun 2008
    vs clubsport
    Aug 2008
    could this be caused by aftermarket ecu
    cause my car hasnt been tuned so its running rough could this be the cause of it to get confused ...
    motor is fresh and also running a diffrent throttle setup then it was before we triggered to run real rough
  1. [SA] To TRADE. VT Clubby front bar and VX clubby side skirts
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 15-03-2009, 11:48 PM
  2. **vs clubby manuel gearbox issue**
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2008, 06:36 PM
  3. vs clubby lag top end issue
    Last Post: 31-10-2008, 06:34 PM
  4. Vs clubby irs diff knock issue
    Last Post: 19-10-2008, 04:40 PM
  5. fuel issue vs clubby
    Last Post: 16-10-2008, 04:17 PM
