Results 1 to 6 of 6
Thread: VR Aircon
    VR Executive
    Aug 2009
    Default VR Aircon
    Ok so a few questions.
    My new VR dosnt have any A/C, not even a switch for it..
    Why is this?
    Did the VR have the option to have A/C or not?
    How much do you think it would cost to set this all up?
    Dont really know what i need either, was thinking bout going to a wreckers or something..
    Could i get some sort of price list if anyone has time?
    Cheers guys!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd reckon it would be cheaper to sell your VR and buy another with a working A/C. To retrofit you need compressor ($400new) evaporator ($200), condenser ($120) , hoses ($200), belts and pulley ($100), regas/oil ($200) plus the labout to remove the entire dash to fit the evap in (8hrs) etc etc. New you wouldn't get out for under $2000 minimum....from a wrecker maybe $1000 or scabbing bits and pieces maybe $500. The hassle would be extreme.
    Fresh air is cheap and freely available.
    chrisdoesitbetter's Avatar
    chrisdoesitbetter is offline | → ³8°º™ ← |
    VR 3.8L
    May 2009
    yeah unless its a project car or something id seel and buy a a/c equipped one...too much hassle for a bit of cold air
    VR Executive
    Aug 2009
    Yeh i wouldnt want to sell it as it is a porject car..
    I found out my mate has still got is VS that he crashed a while back, so ill prbly get everything off that for alot cheaper..(im hoping to stinge him $500 for all of it)
    what kind of work needs to be done to get everything in?
    8hour job? Better to get a professional to do it?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If your mate has a VS that's pranged you can bet your last brass razoo that the aircon got damaged in the prang - if so the gas would have escaped and the outside air would have entered the system...along with moisture which will stuff all the insides of the whole system. The oil used in A/C systems is hygroscopic meaning it absorbs moisture.....then it rusts everything.
    Really....it ain't worth it.
    VR Executive
    Aug 2009
    I see where your comming from..
    Although i will still go and check it out, he only lives around the corner, so i might as well..
    Ill be bringing my sisters boyfriend.. He's a panel beater, and knows a fair bit about cars in general..
    Thanks for the help though mate.
  1. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
  2. VS AirCon
    By Quicksilver in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2006, 05:53 PM
  3. vr aircon
    By craigvl038 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2006, 08:16 PM
  4. aircon fan
    By dibly1980 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2005, 11:02 PM
  5. Aircon
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2003, 11:17 PM
