Results 1 to 2 of 2
Thread: how to change clutch cable?
    VR COMMODORE
    Jul 2008
    Default how to change clutch cable?
    how do u change clutch cable on vr v6 commodore
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Hi Ital,
    on a V6 VR it's quite simple:
    1) remove the black plastic cover above your pedals by removing the plastic screw/plugs
    2) remove the heating ducting in front of the clutch pedal - you may have to remove the end piece that puts air through to the door vents to get this out (remove the three screws which can be seen when your door is open)
    3) disconnect the clutch cable from the clutch pedal
    4) place your car on flat ground and jack it up and put on car stands
    5) remove the plastic clutch cable gearbox cover carefully as the tabs break easily
    6) loosen the tension on the cable housing by twisting the adjustment screw where the clutch cable is mounted onto the gearbox
    7) exchange your clutch cable for a new one and reverse proceedure
    note: if step 3) is impossible due to tension on the cable, do steps 4) 5) & 6) first
    hope that helps,
    JA2Z
    I've made her a Hold-On Commodore
    Foam Tuned 1995 VR Series II - 9psi Boost - Manual - FM Intercooler - 3" S/Steel Plumbing
    Super6 Injectors - Ceramic Wrapped Genie Extractors - 2.5" HiFlow Cat - 2.5" HiFlow Catback Exhaust with a 4" Dump Resonator
  1. Clutch Cable
    By azzfox in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2009, 07:12 PM
  2. vs clutch cable
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2009, 07:15 PM
  3. vs v8 clutch cable
    By vs hay hauler in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2009, 11:48 PM
  4. [WA] WTB: VN-VS T5 clutch cable
    By Chirpstr in forum Swap / Wanted to Buy / Trade
    Last Post: 07-03-2009, 09:04 PM
  5. Clutch Cable on a V6
    By 05 VZ SS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2006, 01:29 PM
