Results 1 to 5 of 5
Thread: VS Air Con Question
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Default VS Air Con Question
    This question probably has a really simple answer but i know nothing about air cons so i thought i would ask.
    What does it mean when my air con goes from cold to warm cold to warm cold to warm constantly. Its like the air con switches off every five minutes then turns back on again. But i don't touch the button, i just leave it on. I really know when the air con goes off, because it gets really stuffy and warm inside the cab. Does my air con need re-gassing or something like that?
    VY SS
    Jun 2006
    Albany
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    Sounds like your TX valve is frezing up and when it warms up again it kicks in. I could be wrong and the best thing to do, is take it to a A/C place get them to check it out
    NEVER LATE IN A 355ci
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    Cheers guys. I know its normal for the air con to switch off when you are overtaking or going up a hill to give you as much power as possible, but mine switches off just when im doing 100km on a straight road. I did'nt think that was normal.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It could also be either low on gas or overfull - both can cause the high pressure switch in the refrigerant system to turn off till pressures drop again. Also could be a bad relay or cables or even a bad fan speed control. It would pay to do some elementary electrical checks before going to an A/C person who "may" want to extract $$$ from you.
    To find out more about A/C do a google search - the way they work is very simple.
  1. 355 question
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2009, 09:59 PM
  2. vs v6 question
    By slingshot76 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-09-2008, 01:51 PM
  3. Sub & Amp Question
    By VRDaniel in forum Car Audio
    Last Post: 18-04-2007, 09:23 PM
  4. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
