Results 1 to 8 of 8
Thread: pacemaker header knock sound underneath
    vs clubsport
    Aug 2008
    Default pacemaker header knock sound underneath
    hey guys i noticed when im on n off the throttle i get a knock sound cuming from the bottom front i put my head under and had a look and noticed the drivers side extractor is slightly touching the front bottom housing of the gearbox is there any way i can have more room so its abit away from it Hrm ??
    **its a vs clubby 5.0l 5speed**
    any ideas cheers
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    not totally uncommon. i think most people just grind a little out the gear box support.
    something that may work is to unbolt the header slightly, wedge a block off wood between header pipe and gearbox, then tighten the bolts again. then run engine and get header real hot. as the header heats it will relax the steel. then remove wood and when it cools it should stay where it is.
    Body by Holden, Soul by Brock
    the Legend will live forever
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Or just get a lever in there and bend it out of the way. It won't need any more than about 10mm clearance as the engine and gearbox move together.
    Although I doubt this is actually where the noise would be coming from. It would be more likely hitting the rack or the cross member.
    Visit my Facebook page
    vs clubsport
    Aug 2008
    its going to the exhuast shop soon so il get it on the hoist and have a good look at it maybe he can help me out with it cheers guys
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    i had a vr ss auto with pacies on it that was hitting on the chassis rail, my mechanic loosened the engine mounts and gently jacked up the motor on the opposite side. i assume this pushed that mount up as far as the slots where the bolt goes thru would allow making the other side drop down before he tightened them back up. it worked, just
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    i think the usualy make a small dent in the extractor so it fits lol ive heard it done before
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You sure they not hitting up under the floor pan somwhere??? Broken engine mounts can contribute to this.
    Reaper
    vs clubsport
    Aug 2008
    the engine mounts are brand new i would get my mechanic to check it out when he gets back from his holidays
  1. knock sound when braking
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2009, 09:45 AM
  2. Tapping underneath car
    By CommodoreMan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2009, 08:25 PM
  3. vs clubsport knock and rattle sound from rear
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2008, 08:11 PM
  4. knock sound from the rear
    Last Post: 19-10-2008, 11:30 AM
  5. Rattle from Ls1 rear/underneath
    By vaertigo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-11-2007, 09:22 PM
