Results 1 to 4 of 4
Thread: 94 VR - Code 16
    acex1138's Avatar
    acex1138 is offline Post Overlord
    Clubspec Evo 8
    Jun 2009
    South Australia - The Nanny State
    Default 94 VR - Code 16
    getting Code 16 - Coolant temperature Sensor voltage unstable
    dont know if its related but she rough's on idle as well after a bit.... how to go about checking up and fixing?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You can remove it and test in hot water but it's a bit of a hassle. I'd check the connectors to the sensor first, then remove the engine fuse for 30 secs to reset the fault codes then check again. If it persists replace the sensor. It will cause the engine to run either rich or lean depending on which way it failed.
    acex1138's Avatar
    Clubspec Evo 8
    Jun 2009
    anyone done a guide on how to fix this or had much experience? i cant find much around.... i havnt replaced a sensor or anything like this so wouldnt know where to begin
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just reset the fault codes as in previous post and see what happens as this may clear up your problem as this procedure als0 resets the ECU - otherwise do a search on this forum for "coolant sensor" and you'll find plenty of posts..
  1. code 63
    By pando666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2009, 08:23 PM
  2. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  3. code 47???? WTF!!!!
    By maco_butterfly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2008, 08:52 PM
  4. code 31
    By bucksta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2006, 07:23 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
