Results 1 to 6 of 6
Thread: Gts 355 big engine problem need help please
    vs hsv gts
    Oct 2009
    Exclamation Gts 355 big engine problem need help please
    Hi im new here but have a huge problem with a mates HSV GTS VS its got a 355 in it and destroid a cam lobe and a hydrolic roller lifter so i got him a new crane billet cam full set of hydrollic roller lifters and push rods and fitted them to cranes specs and how they tolld me to install them but now that new billett cam has no hard faceing left and has destroid more lobes than old cam and isnt even 2 mnths old
    now it gets oil feed to the top of all the roller rockers and has a new oil pump with we did wen we did the cam to rule it out
    So if any one can tell me WTF is going on it would be grate and mabe save me heaps of money lol
    PLEASE HELP WITH WOT YOU THINK IT IS
    i think the cam was faulty wot do you think ?
    vs clubsport
    Mar 2009
    brisbane
    did you run the cam in properly
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    vy
    Mar 2009
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    check roller's and make shure they turn and no flat spot's.
    and as the above post's state. cam run in, and spring bind, valve lean over.
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    How heavy duty did you go with the springs(if you replaced them). Also thinking either faulty cam, rollers or they not run in right.
    Reaper
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    are you running it in properly, using the right lube (pre-lubricating) and not just waiting for oil to make it there?
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. Engine problem!!!!!!!!!! Any help?????
    By Ms 5ltr VK in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2009, 11:32 PM
  2. vn engine fan problem
    By reaper01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2009, 07:35 PM
  3. VE SS ...Engine problem
    By BOY1236 in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-01-2009, 11:50 AM
  4. engine problem
    By Budz in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-09-2008, 08:18 PM
  5. engine bay problem
    By vr_owner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2006, 12:10 AM
