Results 1 to 5 of 5
Thread: fuel pump cavitation in a VS ute
    A bicycle
    Aug 2009
    Gippsland, Victoria
    Default fuel pump cavitation in a VS ute
    g'day everyone,
    i've lately been having some issues in the fuel system in my ute. about 2 weeks ago the fuel pump shat itself so i put a newie in. was all smooth sailing until the fuel level in the tank gets to around 1/3 of the total capacity, and whenever i turn a right hand corner (such as a roundabout) the fuel pump starts cavitating in the tank.
    these tanks have a little bucket like thing that the pump sits in, which i think is to eliminate fuel moving away from the pump and the pump cavitating. which is what it is doing now.
    all the hoses and lines have no leaks or cracks, and the pump is working fine.
    so the only thing i can think of is the little bucket thing has a hole in it or a crack, which is causing the fuel level around the pump being too low when the tank is 1/3 full and the cavitation occuring.
    thoughts, advice, things to look for?
    thanks
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    I have read many threads on this problem. I found one on a quick search:
    VS V6 96 engine dies when turning a sharp corner please help!!!
    You may have dislodged your fuel return line when installing the new pump.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    Quote Originally Posted by aceventura View Post
    ..You may have dislodged your fuel return line when installing the new pump.
    yeah i had a look at that thread before i posted this one, but i know that all the fuel lines are where they should be.
    its really got me beat
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The swirl pot has been known to break during pump changeover as it gets brittle over the years. I think the only fix is a new/secondhand tank.
    A bicycle
    Aug 2009
    Gippsland, Victoria
    Quote Originally Posted by hako View Post
    ahh that makes sense, most likely the problem.
    hmm, might make a long range tank to use up that space... just a thought. dont really need it though.
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
